Appliance Repair Forum
Appliance Repair Forum (
-   Dryer Repair (
-   -   Kenmore dryer not heating (
murphy7513 07-04-2012 09:17 PM
My kenmore dryer is running but I am getting no heat. I am going to order the fuses and try to replace them first. However, I am not sure where they are loacted. Can you help with where they are located. Thanks
denman 07-05-2012 02:30 AM
Replacement parts for Kenmore 11068722700 |
If you go to the Sears parts site they have part breakdowns. Unfortunately they like to keep these in-house so they are not available at AppliancePartsPros. You want to look at the Bulkhead diagram at Sears, the fuses for heat are on the heater assembly (Item 47). See below the APP part. If you click on the picture a new page will open with info on this part.
Part number: AP3094224
No heat can have many causes.
The heater runs off of 240 so check power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
Be careful as 240 volts is lethal !!!
If the power is OK then unplug the unit and check the heating element.
They are usually 8 to 12 ohms.
If OK then check the thermal fuse on the heater assembly.
If blown get back tyo us as you have to look to see what caused it to blow.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
swant50 07-06-2012 02:21 PM
How to take the back of my dryer off?
after removing all hardware, the back will not come off,trying to replace thermostat
denman 07-07-2012 03:35 AM
I believe you have to go in through the front.
The following should help.
Dryer Belt (Whirlpool made dryers, part #341241)-How To Replace - YouTube
Also the Sears parts site has actual parts breakdowns that may be useful.
