Discuss
Maytag Neptune Dryer Problem
 in
Dryer Repair
<H1 style="MARGIN: 24pt 0in 0pt; mso-line-height-alt: 14.4pt">I have a Neptune Dryer with electronic controls - Randomly started buzzing -- The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune Dryer Problem
  #1 (permalink)
Old 09-15-2009, 12:13 PM
Junior Member
PROFESSOR200 is on a distinguished road
Default Maytag Neptune Dryer Problem
Model Number: MDE5500AYW   Brand: Maytag   Age: 1 - 5 years
<H1 style="MARGIN: 24pt 0in 0pt; mso-line-height-alt: 14.4pt">I have a Neptune Dryer with electronic controls - Randomly started buzzing -- The dryer seems to work, but the selector buttons do not all function normally. I tried cutting the power for an hour or so to see if it might reset but it didn't. If I turn it off, and restart it, some of the buttons work, but if I press a couple of them, then one by one they quit or they start the buzzing. If I turn it off and restart it again, the same thing happens.
It does run and dry clothes & it knows when the door is open it just seems like the controls for temp and dryness are not functioning. Sometimes the "off" button won't turn it off unless I open the door. The intermittent buzzing seems to be coming from a relay on the control board. I want to order the part, but don't know if I need AP4043476 , AP4042930 or AP4044079 , the control board.
Can you help me? Thanks,
Ralph
</H1>
Ads By Google
Related Models
Maytag MDE5500AYW Dryer - Ele
Maytag MDE5500AZQ Dryer - Ele
Maytag MDE5500AZW Dryer - Ele
Maytag MDE5806AYK Dryer - Ele
Maytag MDE5806AYW Dryer - Ele
Maytag MDE5806AZK Dryer - Ele
Maytag MDE5806AZW Dryer - Ele
Maytag MDE5960AYW Dryer - Ele
Maytag MDE6000AUW Dryer - Ele
Maytag MDE6000AYQ Dryer - Ele
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
  #2 (permalink)
Old 09-16-2009, 03:59 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAYTAG MDE5500AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag...s/16023110.pdf
AP4043476 is a white keypad
AP4042930 looks like an ivory keypad
AP4044079 is the control board
Try running the diagnostics.
Could also try cleaning the ribbon connector (see below)
Your problem could be caused by bad connections or the control board.
Though I would lean towards the control board since it seems very random.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag Neptune Dryer eisenberger Dryer Repair 7 01-04-2010 04:36 PM
Maytag Neptune Dryer npreese Dryer Repair 3 05-07-2009 03:30 PM
Maytag Neptune bottom venting problem JennaH Dryer Repair 0 12-24-2008 01:43 PM
How to take apart Maytag Neptune Dryer blbette Dryer Repair 1 12-22-2008 05:04 PM
Maytag Neptune Gas Dryer ZMARK Dryer Repair 0 07-19-2008 05:22 AM
