| » Maytag SE1000 Dryer will not heat |
Very likely the problem is a restricted air flow through the vent.
Where does the dryer vent go? Does it go on top of the roof? If it does, it has to be cleaned professionally, by a people with a special equipment to do it right. Visually inspect the heating relay for a burned contacts inside. If there are any, replace the relay. Make sure the blower wheel is not damaged and is not slipping around the motor shaft. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Blockage is the first thing I checked. Prior to posting on the site I removed the front pannel of the dryer, removed the blower wheel housing to access the vent to the back of the dryer, removed the vent tube from the ceiling and removed the vent cap from the roof. I have no attic the roof is the ceiling and there is a two foot tube that runs though the ceiling. There is not much for a profrssional to clean. There was a little lent but not much. Cleaned and replaced everything. No change. The heating element comes on then the relay trips and shuts the element off. The Dryer continues to turn. The blower wheel works as designed I will check the relay. Do I need to check the high limit thermostate? So what is next? How do I troubleshoot for the problem? Follow up: I left the breaker off all night and turned it on in the morning. Ran the dryer again and it dryed through the cycle. Can't explain it other than maybe one of the components in the circut is starting to fail. Any suggestions. Have a happy 4th. Thanks for you help! Last edited by danlajoie : 07-04-2012 at 10:55 AM. |
You are welcome.
It is very hard to diagnose any intermittent problem. I would just use the dryer under control and see how it will work later. The out of temperature range high limit thermostat can be a problem but it's almost impossible to test it in such situation. Much easier just to replace it. - The high limit thermostat Part number: 303396 Gene.
__________________
I don't think so. Replace the relay and post the result.
__________________
Ok R&R the relay and ran the dryer without any clothes. Same thing happen the coils heated up and then the relay tripped and turned it off. What next?
Can you post a pictures of the new and old parts?
__________________
Both the old and new relays have the same part number stamped on top. The new relay pictures were taken on the desk. The old relay picture were taken while it was installed in the dryer.
Update: Replaced the high limit thermostat and ran the dryer with a load of wet clothes. The Cycle completed and the clothes were dry. However, before I conclude it is fixed, I will run it several more times. If it still shuts off then should replace the heat sensor inside the dryer? Last edited by danlajoie : 07-17-2012 at 11:33 AM. |
| Display Modes | |
| Maytag SE1000 stack washer/dryer leaking issue | flyin99 | Washer Repair | 3 | 01-20-2012 06:38 AM |
| SE1000 doesn't start wash cycle | palezo | Washer Repair | 0 | 10-23-2011 06:16 PM |
| Maytag SE1000 stack dryer motor removal | Lynn Finch | Dryer Repair | 0 | 12-23-2009 01:06 PM |
| Maytag SE1000 Motor switch | DNyq | Washer Repair | 2 | 08-29-2008 06:34 AM |
| Maytag SE1000 won't spin or drain | DNyq | Washer Repair | 8 | 08-16-2008 12:33 PM |
