Discuss
Squeaky, clothing catches in drum
 in
Dryer Repair
Had a problem back in June 2009 with brown stain lines on clothes and clothing catching in between the front
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squeaky, clothing catches in drum
  #1 (permalink)
Old 07-01-2012, 01:59 PM
Junior Member
charleswilt is on a distinguished road
Default Squeaky, clothing catches in drum
Model Number: 417.49012890   Brand: Frigidaire   Age: More than 10 years
Had a problem back in June 2009 with brown stain lines on clothes and clothing catching in between the front of the drum and the cabinet....
After reading the posts on this forum, I replaced
AP2150497 Felt glide assembly
AP2143044 Seal/basket lower
Seemed to correct the problem...however it's back, along with a very annoying squeak that sometimes goes away...
Based on what I've found in the site, I'm guessing I'll need to replace (both?) the above again along with
AP2142648 Rear Drum Bearing Kit
Is there anything else I should replace while I'm in there? Possibilities I've found:
AP3886900 Idler Arm Assy
AP3865318 Dryer Drum Belt
Thanks!
Charles
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 07-02-2012, 01:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Charles,
You are on the right track. All these parts should fix it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-02-2012, 03:48 PM
Junior Member
Default
Gene,
Any chance, or how can I tell if I really need another
As it is only 3 years old...
Also, how can I tell if I need
AP3886900
Idler Arm Assy
Thanks!
Or should I just replace them to be safe?
  #4 (permalink)
Old 07-02-2012, 03:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The only way you can figure it out is disassemble the dryer and check it.
__________________
  #5 (permalink)
Old 07-02-2012, 05:02 PM
Junior Member
Default
Never mind...I took a closer look at the other side...it's toast
Thanks!
Charles
  #6 (permalink)
Old 07-05-2012, 01:49 PM
Junior Member
Default
Ok, the drum bearing didn't have any instructions...but I think I got it...
Only thing is when I took the old one off, a little BB size copper ball fell out along with the 1/4 steel ball bearing....
Is the copper ball supposed to be there? Or did I get a BB caught in the dryer at some point?
Charles
  #7 (permalink)
Old 07-05-2012, 02:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Charles,
The 1/4" steel ball bearing must be there but I have no clue about a copper ball. Where it was?
__________________
  #8 (permalink)
Old 07-05-2012, 07:52 PM
Junior Member
Default
Good question...
I didn't see it, I just heard it hit the inside of the cabinet as I was loosening the screws holding the bearing on...
I don't see it in the parts diagram...and there doesn't seem to be a place to put it. So I'm thinking it's just a BB that found it's way inside somehow.
Charles
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Another Kenmore Dishwasher Catches Fire! keithb7 Dishwasher Repair 22 11-07-2011 04:15 PM
ge double oven catches fire!! cfgoldbe Oven Repair (including Ranges and Cooktops) 1 10-27-2010 02:11 PM
Element Catches Fire Karma Oven Repair (including Ranges and Cooktops) 0 08-17-2009 01:06 PM
Drum catches clothes tracksmak Dryer Repair 2 11-24-2008 06:18 AM
