Discuss
Whirlpool ultimate care 2 gas dryer
 in
Dryer Repair
Here is my problem I can't get this dryer to ignite so there is no flame even through the igniter
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool ultimate care 2 gas dryer
  #1 (permalink)
Old 06-27-2012, 12:12 AM
Senior Member
allen9258 is on a distinguished road
Angry Whirlpool ultimate care 2 gas dryer
Brand: Whirlpool   Age: 1 - 5 years
Here is my problem I can't get this dryer to ignite so there is no flame even through the igniter lights up and but it never ignites the gas all the thermostats and thermal fuse are good. I need some help to figure this thing out maybe the flame sensor or the gas vale or maybe the timer is bad can you Please help me with this problem. I tried to find a model number behind the door but it not listed even through all the stickers are there.
  #2 (permalink)
Old 06-27-2012, 08:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Allen,
I've seen couple times when the gas shut off valve behind the dryer was Off. Did you check it? Also some models do have additional shut off valve next to the gas valve inside the dryer. In other word, verify the gas supply for the dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-29-2012, 01:47 AM
Senior Member
Default
there appear to be gas going to it however it may not be making it to the igniter there does not appear to be a cut off near the coils is there a way to see if gas is making it to the igniter i just replaced the coils and the flame sensor however it still won't ignite the gas as through there is no gas reaching the igniter also i have checked the thermal fuse and it's good. can the timer be bad or the gas assembly be at fault?
  #4 (permalink)
Old 06-29-2012, 05:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
As long as the igniter does glow, there is nothing wrong in the ignition circuit.
If the gas shut off valve behind the dryer is completely open and there is proper pressure in the gas supply line, then the problem is a bad dryer gas valve.
__________________
  #5 (permalink)
Old 06-30-2012, 01:05 AM
Senior Member
Default
So the assembly it's self is bad and not the coils is this what you mean?
  #6 (permalink)
Old 07-02-2012, 02:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, that's right.
__________________
  #7 (permalink)
Old 07-03-2012, 06:14 PM
Senior Member
Default
Thanks Gene I will replace it hope this fixes the problem and I can get this dryer working asap
  #8 (permalink)
Old 07-03-2012, 06:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Good luck and keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Ultimate Care II Oakrad1 Washer Repair 0 04-07-2012 06:18 AM
Whirlpool Ultimate Care II fayef Washer Repair 3 10-29-2011 03:02 AM
shoe rack in whirlpool ultimate care dryer lundy123 Dryer Repair 0 07-06-2010 06:17 PM
Whirlpool Gold Senseon Ultimate Care II Dryer shutting off!! thkirkland Dryer Repair 3 11-12-2009 04:42 PM
whirlpool ultimate care 2 higleyml Washer Repair 4 07-05-2009 12:04 PM
