| » Whirlpool Dryer won't start |
Model Number: WGD5540SQO Brand: Whirlpool Age: 1 - 5 years
My Whirlpool gas dryer will not work when pushing start. I have checked power coming in, door switch, and thermal fuse. I am wondering if it could be the timer. When checking W (white wire) and T (tan wire) coming into the timer on the back of the dryer with those wires disconnected from timer and dryer unplugged I get no reading except (L open). Shouldn't that be reading atleast 0.00 or something. Please help ...the timer is $100 and not sure how else to test it or maybe jump it to check to see if that is it.
Hi.
With the door switch and timer contacts BK- BU, T-W closed the dryer should start. You may jump timer contacts to check if it will work. If that is not the timer you have a bad motor. Here are the breakdown diagrams and Replacement parts for Whirlpool WGD5540SQ0 29"GAS DRYER | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thank you Simon,
It was the timer. To double check, we jumped as per your suggestion and then were sure that was it. Ordered the part from Appliance Pros (since local supplier was on backorder) installed this morning and dryer is running great! |
You are very welcome.
Simon.
__________________
| Display Modes | |
| Whirlpool dryer won't start | moonie777 | Dryer Repair | 1 | 05-13-2011 04:00 PM |
| Whirlpool dryer won't start | zebra47cb | Dryer Repair | 2 | 02-24-2011 05:01 PM |
| Whirlpool Dryer will not start | Newglide | Dryer Repair | 5 | 01-14-2011 08:40 AM |
| Whirlpool Dryer Won't Start | AboveTheBULL | Dryer Repair | 4 | 01-24-2010 08:02 AM |
| whirlpool gas dryer will not start | dmicare | Dryer Repair | 1 | 09-19-2007 06:16 PM |
