Discuss
electric dryer
 in
Dryer Repair
The dryer wont turn on. I unpluged and pluged it back on, control panel lights up, and made sure door
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » electric dryer
  #1 (permalink)
Old 09-14-2009, 09:43 AM
Junior Member
makrani12 is on a distinguished road
Default electric dryer
Model Number: Maytag electric dryer # mde5500   Brand: Maytag   Age: 5 - 10 years
The dryer wont turn on. I unpluged and pluged it back on, control panel lights up, and made sure door closed and press start/pause button, nothing happens.
Help
Ads By Google
Related Models
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
Maytag MBB1956HES Ref - Bottom Mounts
Maytag MBB1956HEW Ref - Bottom Mounts
Maytag MBB2254GEB  Ref - Bottom Mounts
Maytag MBB2254GEQ  Ref - Bottom Mounts
Maytag MBB2254GES  Ref - Bottom Mounts
Maytag MBB2254GEW  Ref - Bottom Mounts
Maytag MBB2256GEB  Ref - Bottom Mounts
Maytag MBB2256GEQ  Ref - Bottom Mounts
Maytag MBB2256GES  Ref - Bottom Mounts
Maytag MBB2256GEW  Ref - Bottom Mounts
Maytag MBF1956HEB Ref - Bottom Mounts
Maytag MBF1956HEQ Ref - Bottom Mounts
Maytag MBF1956HES Ref - Bottom Mounts
Maytag MBF1956HEW Ref - Bottom Mounts
Maytag MBF1956KEB Ref - Bottom Mounts
Maytag MBF1956KEQ Ref - Bottom Mounts
Maytag MBF1956KEW Ref - Bottom Mounts
Maytag MBF2254HEB Ref - Bottom Mounts
Maytag MBF2254HEB14 Refrigerator
Maytag MBF2254HEQ Ref - Bottom Mounts
Maytag MBF2254HEQ14 Refrigerator
Maytag MBF2254HES White Westinghouse/refrigerator
Maytag MBF2254HEW Ref - Bottom Mounts
Maytag MBF2254HEW14 Refrigerator
Maytag MBF2255KEB Ref - Bottom Mounts
Maytag MBF2255KEB11 Refrigerator
Maytag MBF2255KEQ Ref - Bottom Mounts
Maytag MBF2255KEQ11 Refrigerator
Maytag MBF2255KEW Ref - Bottom Mounts
Maytag MBF2255KEW11 Refrigerator
Maytag MBF2256HEB Ref - Bottom Mounts
Maytag MBF2256HEQ Ref - Bottom Mounts
Maytag MBF2256HES Ref - Bottom Mounts
Maytag MBF2256HEW Ref - Bottom Mounts
Maytag MBF2256KEB Ref - Bottom Mounts
Maytag MBF2256KEB11 Refrigerator
Maytag MBF2256KEQ Ref - Bottom Mounts
Maytag MBF2256KEQ11 Refrigerator
Maytag MBF2256KEW Ref - Bottom Mounts
Maytag MBF2256KEW11 Refrigerator
Maytag MBF2258HEB Ref - Bottom Mounts
Maytag MBF2258HEQ Ref - Bottom Mounts
Maytag MBF2258HES Ref - Bottom Mounts
Maytag MBF2258HEW Ref - Bottom Mounts
Maytag MBF2262HEB Ref - Bottom Mounts
Maytag MBF2262HEB13 Refrigerator
Maytag MBF2262HEQ Ref - Bottom Mounts
Maytag MBF2262HEW Ref - Bottom Mounts
Maytag MBF2262HEW13 Refrigerator
Maytag MBF2556HEB Ref - Bottom Mounts
Maytag MBF2556HEQ Ref - Bottom Mounts
Maytag MBF2556HES Ref - Bottom Mounts
Maytag MBF2556HEW Ref - Bottom Mounts
Maytag MBF2556HSW Ref - Bottom Mounts
Maytag MBF2556KEB Ref - Bottom Mounts
Maytag MBF2556KEQ Ref - Bottom Mounts
Maytag MBF2556KEW Ref - Bottom Mounts
Maytag MBF2558HEB Ref - Bottom Mounts
Maytag MBF2558HEQ Ref - Bottom Mounts
Maytag MBF2558HES Ref - Bottom Mounts
Maytag MBF2558HEW Ref - Bottom Mounts
Maytag MBF2562HEB Ref - Bottom Mounts
Maytag MBF2562HEQ Ref - Bottom Mounts
Maytag MBF2562HEW Ref - Bottom Mounts
Maytag MBL1952KES Ref - Bottom Mounts
Maytag MBL1956HES Ref - Bottom Mounts
Maytag MBL1956KES Ref - Bottom Mounts
Maytag MBL2255KES Ref - Bottom Mounts
Maytag MBL2255KES12 Refrigerator
Maytag MBL2256KES Ref - Bottom Mounts
Maytag MBL2256KES12 Refrigerator
Maytag MBL2262HES Ref - Bottom Mounts
Maytag MBL2262KES Ref - Bottom Mounts
Maytag MBL2262KES12 Refrigerator
Maytag MBL2556KES Ref - Bottom Mounts
Maytag MBL2562HES Ref - Bottom Mounts
Maytag MBL2562KES 5 Qt. Stand Mixer
Maytag MBQ30 Gas Grill - B/i Stainless St
Maytag MBQ42 Gas Grill - B/i Stainless St
International MBR1415AGS Range - F/s Std Ele
International MBR1415AGW Range - F/s Std Ele
Maytag MBR1952KES Ref - Bottom Mounts
Maytag MBR1956HES Ref - Bottom Mounts
Maytag MBR1956KES Ref - Bottom Mounts
Maytag MBR1980AAB Small Appliances
Maytag MBR1980AAG Small Appliances
Maytag MBR2255KES Ref - Bottom Mounts
Maytag MBR2255KES12 Refrigerator
Maytag MBR2256KES Ref - Bottom Mounts
Maytag MBR2256KES12 Refrigerator
Maytag MBR2262HES Ref - Bottom Mounts
Maytag MBR2262KES Ref - Bottom Mounts
Maytag MBR2262KES12 Refrigerator
  #2 (permalink)
Old 09-14-2009, 10:33 AM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Quote:
Help
This is assuming that the voltage at your outlet is ok.
Something I would want to check are the thermal fuses.
There is one on the where the heating element is located
and one in the blower housing area. Now keep in mind if this
is the culprit there is a "reason why" one of them failed. The one by the
element usually fails because either the heat element coil is shorted
to its metal case or the high limit thermostat is not cycling out
properly. The one in the blower housing can go out because of an airflow issue maybe even due to a striped blower wheel. Although an airflow issue can cause either one of then to go out. You also need to closely examine the vent especially before putting the dryer back in service after its been
repaired.
(With the dryer unplugged) These fuses would have to be checked using an ohmmeter.
If these both check ok then other electrical testing on the dryer will have to be done.
  #3 (permalink)
Old 09-14-2009, 10:37 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Motor drive replacement parts for MAYTAG MDE5500AYQ | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag...s/16023110.pdf
If you have the correct voltage 240 volts from L1 to L2 and 120 volts from L1 to Neutral and L2 to Neutral then odds are high that one of the thermal fuses has blown. Item 11 in the Heater section and Item 10 in the Motor section.
Best to unplug the unit and check them with a meter.
If a thermal fuse is blown be sure to give the interior a good cleaning including the blower wheel. Also clean and check your vent system.
__________________
  #4 (permalink)
Old 09-19-2009, 03:22 PM
Junior Member
Default Maytag Dryer mde5500
Thanks for replying back.
I havent tried anything yet but i really appreciate.
I also noticed that sometimes the dryer console showed 18 for no reason. So i unplugged it and plug it back and would go away for couple of days. So is that a code or just a coincedence.
Please let me know.
Tony
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
ELECTRIC Dryer Max Harlan Dryer Repair 6 04-26-2009 05:51 AM
Electric dryer will not run GA60 Dryer Repair 0 02-08-2009 06:10 AM
Electric dryer gets too hot cojo1957 Dryer Repair 2 10-28-2008 04:50 AM
Gas dryer to electric dryer convertion. Fhabeeow Dryer Repair 1 01-08-2008 07:49 PM
