Discuss
Amana NED7200TW No hot air
 in
Dryer Repair
Hello, I have the Amana dryer model listed above, and today it stopped producing hot air even though it continues
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana NED7200TW No hot air
  #1 (permalink)
Old 06-24-2012, 08:12 PM
Junior Member
benfinkel is on a distinguished road
Default Amana NED7200TW No hot air
Model Number: NED7200TW   Brand: Amana   Age: 1 - 5 years
Hello,
I have the Amana dryer model listed above, and today it stopped producing hot air even though it continues to run just fine otherwise.
I checked the normal things, like the lint hose, etc... and all looks clear and good.
The general consensus online was to check the thermostat(s) and replace them if necessary. I found a tech sheet and looked up the diagnostic codes on the control panel but nothing about the thermostats came up just one instance of 10 - No Wet Clothes. I cleared that code and started the dryer again and no more codes are coming up now.
Attached is the tech sheet I found.
I've got a few questions:
1) I took off the top, the control panel, and the front panel and still didn't have access to the thermostats. They're buried back under the dryer bin. I was able to unscrew the unit and sort of pull it out, but it wasn't easy and clearly not intended. How am I supposed to get to those?
2) I'll be honest, I don't really know how to use my digital multimeter to test the thermostats. I don't have a "continuity" setting on the dial, just a bunch of different Ohms levels (200,2000,200k,2000k) and a tone setting. I did hear a tone when I touched the leads to the wires.
Thanks in advance!
-Ben
Ads By Google
Related Models
Maytag NED7200TW10 29" Electric Dryer
Maytag NEDNS249-F  Ref - SXS/I&W
Maytag NEDNS249-FA  Ref - SXS/I&W
Maytag NEDNS249F  Ref - SXS/I&W
Maytag NEDNS249FA  Ref - SXS/I&W
Maytag NEDNS249FH  Ref - SXS/I&W
Maytag NEDNS249H  Ref - SXS/I&W
Maytag NEDNS249HA  Ref - SXS/I&W
Maytag NEDNS249HH  Ref - SXS/I&W
Norge NEF3G1 Range - F/s Std Ele
Norge NEF3G8DEV Range - S/c F/s Ele
Norge NEF6G6CLW Range - F/s Cont Clean Ele
Norge NEH2H0 Range - F/s Std Ele
Norge NEH3G8CV Range - S/c F/s Ele
Norge NEH3G8DX Range - S/c F/s Ele
Norge NEH6G6CLW Range - F/s Cont Clean Ele
Norge NEHA86-1 Range - S/c F/s Ele
Norge NEHW86-1 Range - S/c F/s Ele
Bosch NEM732 UC
Bosch NEM735 UC
Bosch NEM736 UC
Bosch NEM932 UC
Bosch NEM935 UC
Bosch NEM936 UC
Maytag NENS207G  Ref - SXS/I&W
Maytag NENS207GA  Ref - SXS/I&W
Maytag NENS207GH  Ref - SXS/I&W
Maytag NENS208GZ  Ref - Sxs
Maytag NENS208GZA  Ref - Sxs
Maytag NENS208GZH  Ref - Sxs
Maytag NENS208GZW  Ref - Sxs
Maytag NENS227F  Ref - Sxs
Maytag NENS227F-H  Ref - Sxs
Maytag NENS227FA  Ref - Sxs
Maytag NENS227FH  Ref - Sxs
Maytag NENS227G  Ref - Sxs
Maytag NENS227GA  Ref - Sxs
Maytag NENS227GH  Ref - Sxs
Maytag NENS228GZ  Ref - Sxs
Maytag NENS228GZA  Ref - Sxs
Maytag NENS228GZH  Ref - Sxs
Maytag NENS228GZW  Ref - Sxs
Maytag NENS248GZ  Ref - Sxs
Maytag NENS248GZA  Ref - Sxs
Maytag NENS248GZH  Ref - Sxs
Maytag NENS248GZW  Ref - Sxs
Maytag NENT156E  Ref - Top Mount
Maytag NENT156E-1  Ref - Top Mount
Maytag NENT156EA  Ref - Top Mount
Maytag NENT156EH  Ref - Top Mount
Maytag NENT156G  Ref - Top Mount
Maytag NENT156GA  Ref - Top Mount
Maytag NENT156GH  Ref - Top Mount
Maytag NENT156H  Ref - Top Mount
Maytag NENT156HA  Ref - Top Mount
Maytag NENT156HH  Ref - Top Mount
Maytag NENT156HW  Ref - Top Mount
Maytag NENT176H  Ref - Top Mount
Maytag NENT176HA  Ref - Top Mount
Maytag NENT176HH  Ref - Top Mount
Maytag NENT196H  Ref - Top Mount
Maytag NENT196HA  Ref - Top Mount
Maytag NENT196HH  Ref - Top Mount
Maytag NENT198H  Ref - Top Mount
Maytag NENT198HA  Ref - Top Mount
Maytag NENT198HH  Ref - Top Mount
Maytag NENT198K  Ref - Top Mount
Maytag NENT198KA  Ref - Top Mount
Maytag NENT217F  Ref - Top Mount
Maytag NENT217F-  Ref - Top Mount
Maytag NENT217F-A  Ref - Top Mount
Maytag NENT217FA  Ref - Top Mount
Maytag NENT217FH  Ref - Top Mount
Maytag NENT238H  Ref - Top Mount
Maytag NENT238HA  Ref - Top Mount
Maytag NENT238HH  Ref - Top Mount
Norge NER1360ACW Range - F/s Std Ele
International NER1360AGH Range - F/s Std Ele
Norge NER3540ACW Range - S/c F/s Ele
Norge NER3760ACW Range - S/c F/s Ele
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 Range - F/s Std Ele
Norge NEW2H0 Range - F/s Std Ele
Norge NEW2H1 Range - F/s Std Ele
Norge NEW3G1 Range - F/s Std Ele
Norge NEW3G8AC Range - S/c F/s Ele
Norge NEW3G8CV Range - S/c F/s Ele
Norge NEW3G8CX Range - S/c F/s Ele
Norge NEW3G8DEV Range - S/c F/s Ele
Norge NEW3G8DX Range - S/c F/s Ele
Norge NEW3G8EV Range - S/c F/s Ele
Norge NEW3G8EVW Range - S/c F/s Ele
Norge NEW3H2EX Range - F/s Std Ele
Norge NEW3H8CVW Range - S/c F/s Ele
Norge NEW3H8CX Range - S/c F/s Ele
Norge NEW3H8STVW-EV Range - S/c F/s Ele
Norge NEW3J8EV Range - S/c F/s Ele
Norge NEW6G6CLW Range - F/s Cont Clean Ele
Norge NEW6H6CLW Range - F/s Cont Clean Ele
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Maytag NFW7200TW10 Automatic Washer
Amana NG2119 Washer - Top Loading
Amana NG3319 Washer - Top Loading
Amana NG3519 Washer - Top Loading
Amana NG4319 Washer - Top Loading
Amana NG4519 Washer - Top Loading
Amana NG4619 Washer - Top Loading
Amana NG4719 Washer - Top Loading
  #2 (permalink)
Old 06-25-2012, 03:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Ben,
You may want to start from verifying 240 VAC to the dryer. Unplug the dryer. Remove the cover from the terminal block on the back of the dryer and visually inspect the power cord wires connections to the terminal block.
If there is nothing wrong, plug the dryer back and measure the voltage between the Black & the White and the Red & the White wires. The normal reading suppose to be about 120 VAC.
If these readings are correct, measure the voltage between the Black & the Red wires. The normal reading suppose to be about 240 VAC.
Be careful not to electrocute yourself. Read the owners manual for the multimeter you are going to use before doing any measurements.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
Here are the breakdown diagrams and Replacement parts for Maytag NED7200TW10 29" ELECTRIC DRYER | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana bubaski Washer Repair 1 01-10-2012 09:53 PM
Amana NED7200TW Replaced Theristor based on ts error sylvanl Dryer Repair 0 06-24-2011 03:31 PM
Amana NED7200TW wont tumble ruffrida2005 Dryer Repair 3 04-18-2011 02:25 PM
Amana NED7200TW wont tumble ruffrida2005 Dryer Repair 0 04-11-2011 05:04 PM
Amana bercegeayb Heating, Ventilation, and Air Conditioning (HVAC) 0 08-08-2009 05:29 PM
