Gails
#1 Posted : Thursday, June 21, 2012 5:52:58 PM(UTC)
Gails
Dryer only stays on if you hold in the start button
#2 Posted : Friday, June 22, 2012 1:45:34 AM(UTC)
Replacement parts for Kenmore 11060172002 | AppliancePartsPros.com
See the attachment for the wiring diagram.
If you look at the wiring diagram you will see a switch just to the right of the motor. This is a centrifugal switch, is is supposed to change when the motor gets close to operating speed. It removes the motor's start winding as leaving it in circuit would overheat the motor.
But it also provides a parallel circuit path for the start switch so that you can release the switch and the unit keeps running.
Sounds like it is not making contact to 6M.
Check that you do not have a wire off or a bad connection here.
Check that the motor is not clogged solid with lint.
You did not mention that the motor overheats but perhaps you have not let it run long enough.
The other centrifugal switch switches in the heater so that there is not heat without air flow.
You did not say if there is heat with the motor not running.
If this is the case then there is a problem with the mechanical parts of the centrifugal mechanism in the motor.
This may be that it is just clogged solid with lint.
Unfortunately you cannot just replace the switch you have to replace the entire motor.
Part number: AP3094245
Click on the picture for more info.
File Attachment(s):
60172002.pdf (194kb) downloaded 0 time(s).
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
