NO HEAT FOUND THAT i GET 23 VOLTS TO PLUG FOR IGNITOR AND IT DOESNT GLOW. THE RESISTANCE ACROSS IGNITOR IS 145 OHMS .NOT SURE IF VOLTAGE IS CORRECT OR THE OHMS VALUE IS RIGHT THANKS pAUL
