Discuss
Dryer will not shut off in automatic cycle
 in
Dryer Repair
The dryer will not shut off in automatic dry cycle. The heat works, so it is drying the clothes but
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not shut off in automatic cycle
  #1 (permalink)
Old 06-21-2012, 01:02 PM
Junior Member
jennarnott is on a distinguished road
Unhappy Dryer will not shut off in automatic cycle
Model Number: ale643raw   Brand: Amana   Age: 5 - 10 years
The dryer will not shut off in automatic dry cycle. The heat works, so it is drying the clothes but it continues running long after they are dry.
The duct is clear, the lint trap is clean.
One person told me it could be a humidistat, another told me it was a moisture sensor issue. I still don't know how to fix it! I'd hate to scrap the whole dryer if it is something easily fixed.
Ads By Google
Related Models
Amana ALE643RAW Dryer - Ele
Amana ALE643RBC Dryer - Ele
Amana ALE643RBW Dryer - Ele
Amana ALE643RCW Dryer - Ele
Amana ALE665SAC Dryer - Ele
Amana ALE665SAW Dryer - Ele
Amana ALE866SAC Dryer - Ele
Amana ALE866SAW Dryer - Ele
Amana ALE866SBC Dryer - Ele
Amana ALE866SBW Dryer - Ele
Amana ALE866SCW Dryer - Ele
Amana ALE868QAW Dryer - Ele
Amana ALE868QCW Washer - Top Loading
Amana ALE956EAC Dryer - Ele
Amana ALE956EAW Dryer - Ele
Whirlpool ALF12420
Whirlpool ALF15040
Whirlpool ALF20040
Whirlpool ALF21040
Whirlpool ALF24040
Whirlpool ALFE0940
Whirlpool ALFH0820
Whirlpool ALFW0940
Amana ALG120RAW Dryer - Gas
Amana ALG230RAW Dryer - Gas
Amana ALG230RCW Dryer - Gas
Amana ALG331RAC Dryer - Gas
Amana ALG331RAW Dryer - Gas
Amana ALG331RMC Dryer - Gas
Amana ALG331RMW Dryer - Gas
Amana ALG443RAC Dryer - Gas
Amana ALG443RAW Dryer - Gas
Amana ALG443RCW Dryer - Gas
Amana ALG565SAC Dryer - Gas
Amana ALG565SAW Dryer - Gas
Amana ALG643RAC Dryer - Gas
Amana ALG643RAW Dryer - Gas
Amana ALG643RBC Dryer - Gas
Amana ALG643RBW Dryer - Gas
Amana ALG643RMC Dryer - Gas
Amana ALG643RMC1 Washer - Top Loading
Amana ALG643RMW Washer - Top Loading
Amana ALG643RMW1 Washer - Top Loading
Amana ALG665SAC Dryer - Gas
Amana ALG665SAW Dryer - Gas
Amana ALG866SAC Dryer - Gas
Amana ALG866SAW Dryer - Gas
Amana ALG866SBC Dryer - Gas
Amana ALG866SBW Dryer - Gas
Amana ALG866SCW Dryer - Gas
Amana ALG868QAW Dryer - Gas
Amana ALG868QCW Washer - Top Loading
Amana ALG956EAC Dryer - Gas
Amana ALG956EAW Dryer - Gas
Whirlpool ALJ00520
Whirlpool ALJ07520
Whirlpool ALJ10020
Whirlpool ALJ12020
Whirlpool ALJ18040
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
International ALR1100AJQ Range - F/s Std Gas
International ALR1100AJW Range - F/s Std Gas
International ALR1420BDQ Range - F/s Std Gas
International ALR1420BDW Range - F/s Std Gas
Admiral ALR1450AJW Range - F/s Std Gas
International ALR1450BJW Range - F/s Std Gas
International ALR5715QDQ Range - S/c F/s Gas
International ALR5715QDS Range - S/c F/s Gas
International ALR5715QDW Range - S/c F/s Gas
Amana ALW110RAW Washer - Top Loading
Amana ALW210RAW Washer - Top Loading
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMW Washer - Top Loading
International ALW221RJW Washer - Top Loading
Amana ALW410DAW Washer - Top Loading
Amana ALW430RAC Washer - Top Loading
Amana ALW430RAW Washer - Top Loading
Amana ALW432RAW  Washer - Top Loading
Amana ALW450QAC Washer - Top Loading
Amana ALW450QAW Washer - Top Loading
Amana ALW480DAC Washer - Top Loading
Amana ALW480DAW Washer - Top Loading
Amana ALW540RAC Washer - Top Loading
Amana ALW540RAW Washer - Top Loading
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMW Washer - Top Loading
Amana ALW680RAC Washer - Top Loading
Amana ALW680RAW Washer - Top Loading
Amana ALW780QAC Washer - Top Loading
Amana ALW780QAW Washer - Top Loading
Amana ALW780QMC Washer - Top Loading
Amana ALW780QMW Washer - Top Loading
  #2 (permalink)
Old 06-22-2012, 02:18 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Amana ALE643RAW DRYER- ELE | AppliancePartsPros.com
Since you specifically mentioned auto cycles I am asuming that the unit does shut off in timed dry.
I could not find a wiring diagram for this unit but can say.
The unit does not have a humidistat.
I also could not find a moisture sensor or it's control board in the parts and no mention of one in the operators manual.
If it does have one it will be two metal strips mounted on plastic inside the drum area or on the back of the drum.
If I assume that it does not have a sensor then the way auto works is that the timer motor gets power through the heating element when the heater is shut off.
Unplug the unit and both wires at the heating element.
Measure across the element, usually around 8 to 12 ohms.
Also measure from each side of the heater to the frame. Both should be infinite ohms.
If not the element is grounded and should be replaced.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Automatic dryer shut off edsergent Dryer Repair 3 02-16-2012 02:07 PM
Whirlpool Dryer Automatic Dry Cycle not working christyhecht Dryer Repair 5 07-29-2011 06:28 AM
Speed Queen dryer will not shut of in automatic mode thouse1330 Dryer Repair 1 09-09-2010 06:10 AM
Dryer will not shut off in Automatic Mode ccasler Dryer Repair 3 03-05-2009 10:20 PM
Automatic Permanent Press Cycle fails to shut off DECALGUY Dryer Repair 3 08-04-2007 07:28 PM
