should I get on open reading for flame detector. i removed purple wire and left both white wire intact and went across detectorI also get 145 ohms for ignitor is that reading ok thanks paul
Groups: APP Team
Hi.
The flame sensor should be closed at room temperature, if it's open - replace it.
Simon.
