Kenmore stackable sounds like loose screws
Hello everyone.
I have an over/under Kenmore washer/dryer combo that sounds as if there are screws loose on the outside of the dryer drum when it is turned on. It can also sound like a wrenching rubbing noise. Any suggestions? Thanks in advance. |
What is the complete model number of the unit?
Gene. |
Gene,
It is kenmore model 131639100D (0503). Thanks, Chris |
Hi Chris,
The model number you posted is not a valid Kenmore model number. Verify and repost it please. Gene. |
Thanks gene. I'll update and repost.
Ok. The correct model # is 131719300 9711.
Thanks, Chris |
Chris,
Where did you find it? The model number should be on top of the dryer, on the dryer door frame or under the washer lid. Gene. |
Gene,
Sorry I just saw this message. I will look again for a different model number. Thanks, Chris Quote:
| All times are GMT -7. The time now is 12:45 PM. |
