Discuss
throws circuit breaker
 in
Dryer Repair
My dryer runs fine and I believe overheats. Then the circuit breaker throws. I can run it without heat with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » throws circuit breaker
  #1 (permalink)
Old 06-19-2012, 05:15 PM
Junior Member
jugendstil is on a distinguished road
Question throws circuit breaker
Model Number: DLB155)B   Brand: Hotpoint   Age: More than 10 years
I can run it without heat with no problem. There is no problem with the outlet or plug itself. Suggestions? Thermostat? I have cleaned all the ducting, pulled it away from the wall, removed all lint..there are no obstructions.
Ads By Google
Related Models
General Electric DLB1550BAL Electric dryer
General Electric DLB1550BBL Electric dryer
General Electric DLB1550BCL Electric dryer
General Electric DLB1550BDL Electric dryer
General Electric DLB1550BEL Electric dryer
General Electric DLB1550BNL Electric dryer
General Electric DLB1550RAL Electric dryer
General Electric DLB1550SBLAD Electric dryer
General Electric DLB1550SBLWH Electric dryer
General Electric DLB2450BDL Electric dryer
General Electric DLB2450BEL Electric dryer
General Electric DLB2450BNL Electric dryer
General Electric DLB2450RAL Electric dryer
General Electric DLB2650BAL Electric dryer
General Electric DLB2650BBL Electric dryer
General Electric DLB2650BCL Electric dryer
General Electric DLB2650BDL Electric dryer
General Electric DLB2650BEL Electric dryer
General Electric DLB2650BGL Electric dryer
General Electric DLB2650BNL Electric dryer
General Electric DLB2650RAL
General Electric DLB2650RALWW Electric dryer
General Electric DLB2650TA Electric dryer
General Electric DLB2654TA Electric dryer
General Electric DLB2750BAL Electric dryer
General Electric DLB2750BNL Electric dryer
General Electric DLB2880BAC Electric dryer
General Electric DLB2880DAL Electric dryer
General Electric DLB2880DBL Electric dryer
General Electric DLB2880DCL Electric dryer
General Electric DLB2880DDL Electric dryer
General Electric DLB2880DEL Electric dryer
General Electric DLB2880DGL Electric dryer
General Electric DLB2900MAL Electric dryer
General Electric DLB3000SBLWH Electric dryer
General Electric DLB3200SBLWH Electric dryer
General Electric DLB3400SBLAD Electric dryer
General Electric DLB3400SBLWH Electric dryer
General Electric DLB3600SBLAD Electric dryer
General Electric DLB3600SBLWH Electric dryer
General Electric DLB3600SBLWW Electric dryer
General Electric DLB3800SBLAD Electric dryer
General Electric DLB3800SBLWH Electric dryer
General Electric DLB3800SBLWW Electric dryer
General Electric DLB3900SAM Electric dryer
General Electric DLB3900SBM Electric dryer
General Electric DLB6850AAL Electric dryer
General Electric DLB6850BAL Electric dryer
General Electric DLB6850BBL Electric dryer
General Electric DLB6850BCL Electric dryer
General Electric DLB6850BDL Electric dryer
General Electric DLB6850BEL Electric dryer
General Electric DLB6850TA Electric dryer
General Electric DLB6850TDL Electric dryer
General Electric DLB6850TM Washer
Amana DLD10E Commercial Microwaves
Amana DLD10M Commercial Microwaves
Amana DLD10SE Commercial Microwaves
Amana DLE231RAW Dryer - Ele
Amana DLE330RAW Dryer - Ele
Amana DLE330RCW Dryer - Ele
Amana DLG231RAW Dryer - Gas
Amana DLG330RAW Dryer - Gas
Amana DLG330RCW Dryer - Gas
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2884TC Washer
General Electric DLL2900MAL Gas dryer
  #2 (permalink)
Old 06-19-2012, 06:59 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for DLB155)B models | AppliancePartsPros.com
Unplug the unit and the wires at the elements.
Be sure to mark them or make yourself a diagram.
Then measure across the elements using a meter I am not sure what they should be but they should have continuity anywhere from 10 to 50 ohms.
Then measure from each element connector to the frame, they should all be infinite ohms.
If not an element has broken and is touching the frame, this can cause it to run hot as the thermostats cannot regulate it.
It can also pull excessive current, blowing your breaker.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer throws circuit breaker carolr Dryer Repair 4 01-19-2012 10:36 AM
Washer doesn't run at all, throws circuit breaker on restart attempt Eyzcanoe Washer Repair 8 01-13-2012 04:01 PM
Kicks my circuit breaker FrankoCamp Washer Repair 1 04-05-2009 02:14 PM
Dishwasher stops; throws breaker cvmort Dishwasher Repair 1 10-29-2008 05:16 PM
Circuit breaker Mark Spring Dryer Repair 1 11-27-2007 11:53 AM
