Discuss
Whirlpool LGQ9857LW0 Intermittent heat
 in
Dryer Repair
Great unit- believe only real repair to date was the thermal fuse one time. I changed the heating element in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool LGQ9857LW0 Intermittent heat
  #1 (permalink)
Old 06-17-2012, 05:08 PM
Junior Member
deanm11 is on a distinguished road
Default Whirlpool LGQ9857LW0 Intermittent heat
Model Number: LGQ9857LW0   Brand: Whirlpool   Age: 5 - 10 years
Great unit- believe only real repair to date was the thermal fuse one time. I changed the heating element in error before getting the fuse that time. With the current problem, I did change the flame sensor but this was not a bad part and did not change my problem.
Usually the dryer will glow and flame at start up. The dyer will do its cycling and eventually it will not flame up when the igniter comes on again/glows. The glow seems strong and for a decent amount of time. The two high limit, operating thermostat and thermal fuse all test with good continuity with no power and the unit cool.
Suggested next steps? Many thanks.
Related Models
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
Whirlpool LGR3624PQ1 29" GAS DRYER
Whirlpool LGR3634EW0 GAS DRYER
Whirlpool LGR3634EW1 GAS DRYER
Whirlpool LGR3634EW2 GAS DRYER
Whirlpool LGR3634EW3 GAS DRYER
Whirlpool LGR3634JW0 GAS DRYER
Whirlpool LGR3634JW1 RESIDENTIAL DRYER
Whirlpool LGR3634JW2 GAS DRYER
Admiral LGR3725ADC RANGE- S/C F/S GAS
Whirlpool LGR4434AN0 GAS DRYER
Whirlpool LGR4434AN1 GAS DRYER
Whirlpool LGR4434AQ0 Residential Dryer
Whirlpool LGR4434AQ1 GAS DRYER
Whirlpool LGR4434AW0 Residential Dryer
Whirlpool LGR4434AW1 GAS DRYER
Whirlpool LGR4436AW0 Residential Dryer
Whirlpool LGR4600PQ0 29" GAS DRYER
Whirlpool LGR4600PQ1 29" GAS DRYER
Whirlpool LGR4624BN0 GAS DRYER
Whirlpool LGR4624BN1 GAS DRYER
Whirlpool LGR4624BN2 GAS DRYER
Whirlpool LGR4624BQ0 GAS DRYER
Whirlpool LGR4624BQ1 GAS DRYER
Whirlpool LGR4624BQ2 GAS DRYER
Whirlpool LGR4624BW0 GAS DRYER
Whirlpool LGR4624BW1 GAS DRYER
Whirlpool LGR4624BW2 GAS DRYER
Whirlpool LGR4624DQ0 GAS DRYER
Whirlpool LGR4624DQ1 GAS DRYER
Whirlpool LGR4624DZ0 GAS DRYER
Whirlpool LGR4624DZ1 GAS DRYER
Whirlpool LGR4634BQ0 GAS DRYER
Whirlpool LGR4634BQ1 GAS DRYER
Whirlpool LGR4634BQ2 GAS DRYER
Whirlpool LGR4634DQ0 DRYERS
Whirlpool LGR4634DQ1 GAS DRYER
Whirlpool LGR4634DQO GAS DRYER
Whirlpool LGR4634DZ0 DRYERS
Whirlpool LGR4634DZO GAS DRYER
Whirlpool LGR4634EQ0 GAS DRYER
Whirlpool LGR4634EQ1 GAS DRYER
Whirlpool LGR4634EQ2 GAS DRYER
Whirlpool LGR4634EQ3 GAS DRYER
Whirlpool LGR4634EW0 GAS DRYER
Whirlpool LGR4634EZ0 GAS DRYER
Whirlpool LGR4634EZ1 GAS DRYER
Whirlpool LGR4634EZ2 GAS DRYER
Whirlpool LGR4634EZ3 GAS DRYER
Whirlpool LGR4634JQ0 GAS DRYER
Whirlpool LGR4634JQ1 GAS DRYER
Whirlpool LGR4634JQ2 GAS DRYER
Whirlpool LGR4634JQ3 29" GAS DRYER
Whirlpool LGR4634JT0 GAS DRYER
Whirlpool LGR4634JT1 GAS DRYER
Whirlpool LGR4634JT2 GAS DRYER
Whirlpool LGR4634JT3 29" GAS DRYER
Whirlpool LGR4634JZ0 GAS DRYER
Whirlpool LGR4634JZ1 GAS DRYER
Whirlpool LGR4634PQ0 29" GAS DRYER
Whirlpool LGR4634PQ1 29" GAS DRYER
Whirlpool LGR4634PT0 29" GAS DRYER
Whirlpool LGR4634PT1 29" GAS DRYER
Whirlpool LGR5434AW0 Residential Dryer
Whirlpool LGR5600HQ0 GAS DRYER
Whirlpool LGR5600HZ0 GAS DRYER
Whirlpool LGR5600JQ0 GAS DRYER
Whirlpool LGR5600JQ1 RESIDENTIAL DRYER
Whirlpool LGR5600JT0 GAS DRYER
Whirlpool LGR5600JT1 RESIDENTIAL DRYER
Whirlpool LGR5620KQ0 RESIDENTIAL DRYER
Whirlpool LGR5620KQ1 GAS DRYER
Whirlpool LGR5620KQ2 29"GAS DRYER
Whirlpool LGR5624BN0 GAS DRYER
Whirlpool LGR5624BN1 GAS DRYER
Whirlpool LGR5624BN2 GAS DRYER
Whirlpool LGR5624BW0 GAS DRYER
Whirlpool LGR5624BW1 GAS DRYER
Whirlpool LGR5624BW2 GAS DRYER
Whirlpool LGR5624DQ0 DRYERS
  #2 (permalink)
Old 06-18-2012, 10:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad gas valve coils.
- The coil kit Part number: 279834
Part number: 279834
Here are the breakdown diagrams and Replacement parts for Whirlpool LGQ9857LW0 RESIDENTIAL DRYER | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer intermittent heat jbjbuild Dryer Repair 2 11-04-2011 04:01 AM
Whirlpool Intermittent Heat in Oven Michael McBride Oven Repair (including Ranges and Cooktops) 0 11-15-2010 08:56 PM
whirlpool dryer intermittent heat judydollar Dryer Repair 0 08-30-2010 05:06 PM
Old Whirlpool Gas Dryer Intermittent heat chainz Dryer Repair 1 02-06-2010 11:56 AM
Intermittent heat fxn001 Dryer Repair 1 07-13-2009 01:18 PM
