| » kenmore elite no glow igniter |
Model Number: 110.92822101 Brand: Kenmore Age: 1 - 5 years
kenmore elite gas dryer. last week wife says no heat in dryer. I remove kick plate and clean out a ton of lint. find igniter and start machine. It lights up and cycles through a come of gas lightings so I shut it down and put it all back together again no light. Take it all apart and take out igniter looks like it has a bad spot on it so i replaced it today and still no glow. Tested the high limit fuse and radiant heat fuse both have continuity. Does this mean that I should replace the M series ignition valves now? How do they prevent the ignitor from glowing? I can understand them no allowing the flow of gas but...
I also do not have the unit out of the cabinet. I'm trying to fix it through the kick panel so please keep that in mind. The control panel is working and the drum turns, the vent is clear with very good flow. any help would be appreciated. Ads By Google Related Models Last edited by taz456 : 06-17-2012 at 01:22 PM. Reason: more info |
| Display Modes | |
| dryer igniter will not glow | hrdrockmom | Dryer Repair | 2 | 03-14-2012 11:10 AM |
| Kenmore Elite igniter not working properly | hawknlv | Oven Repair (including Ranges and Cooktops) | 3 | 11-01-2010 09:46 AM |
| Igniter doesn't glow | forna | Dryer Repair | 2 | 10-27-2010 05:19 PM |
| Gas dryer with new fuse, thermostat & igniter. Igniter did NOT glow & no heat | yzhong | Dryer Repair | 1 | 08-10-2009 04:03 PM |
| glow igniter | mackdj10@gmail.com | Oven Repair (including Ranges and Cooktops) | 1 | 06-01-2009 02:51 PM |
