Discuss
Maytag DRYER SHUTS OFF AFTER 10 MIN
 in
Dryer Repair
My dryer will run for about 10 min and then shuts down. have changed out the motor already. inside the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag DRYER SHUTS OFF AFTER 10 MIN
  #1 (permalink)
Old 06-16-2012, 02:56 AM
Junior Member
rzbackfan is on a distinguished road
Default Maytag DRYER SHUTS OFF AFTER 10 MIN
Model Number: SDE 2606 AYW   Brand: Maytag   Age: 5 - 10 years
My dryer will run for about 10 min and then shuts down. have changed out the motor already. inside the drum is hot when it shuts down. after it cools back down then you can restart it. and it will run for about 10 min and then shuts down.
Ads By Google
Related Models
Maytag SDE2606AYW Dryer - Ele
Maytag SDE305DAYW Dryer - Ele
Maytag SDE305DAZW Dryer - Ele
Maytag SDE3606AYQ Dryer - Ele
Maytag SDE3606AYW Dryer - Ele
Maytag SDE3606AZW Dryer - Ele
Maytag SDE4000AYW Dryer - Ele
Maytag SDE4000AZW Dryer - Ele
Maytag SDE405DAYW Dryer - Ele
Maytag SDE4606AYW Dryer - Ele
Maytag SDE4606AZW Dryer - Ele
Maytag SDE505DAYQ Dryer - Ele
Maytag SDE505DAYW Dryer - Ele
Maytag SDE505DAZW Dryer - Ele
Maytag SDE515DAYW Dryer - Ele
Maytag SDE515DAZW Dryer - Ele
Maytag SDE5401AYQ Dryer - Ele
Maytag SDE5401AYW Dryer - Ele
Maytag SDE5401AZW Dryer - Ele
Maytag SDE5701AYQ Dryer - Ele
Maytag SDE5701AYW Dryer - Ele
Maytag SDE5701AZW Dryer - Ele
Whirlpool SDF3700W0
Whirlpool SDF3700W2
Whirlpool SDF3700W4
Whirlpool SDF3700W5
Whirlpool SDF3700W6
Whirlpool SDF4000W0
Whirlpool SDF4000W1
Whirlpool SDF4500W0
Whirlpool SDF4500W1
Whirlpool SDF4500W2
Whirlpool SDF4500W3
Whirlpool SDF4500W4
Whirlpool SDF5000W0
Whirlpool SDF5000W1
Whirlpool SDF5000W2
Whirlpool SDF5000W3
Whirlpool SDF5000W4
Whirlpool SDF5000W5
Whirlpool SDF5000W6
Whirlpool SDF6000W0
Whirlpool SDF6000W1
Whirlpool SDF6000W2
Whirlpool SDF6000W3
Whirlpool SDF6000W4
Whirlpool SDF7000W0
Whirlpool SDF7000W1
Whirlpool SDF7800W0
Whirlpool SDF7800W1
Whirlpool SDF7800W2
Whirlpool SDF7800W3
Whirlpool SDF7801W0
Whirlpool SDF8000W0
Whirlpool SDF8000W1
Maytag SDG2606AWW Dryer - Gas
Maytag SDG305DAWW Dryer - Gas
Maytag SDG3606AWQ Dryer - Gas
Maytag SDG3606AWW Dryer - Gas
Maytag SDG4000AWW Dryer - Gas
Maytag SDG405DAWW Dryer - Gas
Maytag SDG4606AWW Dryer - Gas
Maytag SDG505DAWQ Dryer - Gas
Maytag SDG505DAWW Dryer - Gas
Maytag SDG505DAXW Dryer - Gas
Maytag SDG515DAWW Dryer - Gas
Maytag SDG5401AWQ Dryer - Gas
Maytag SDG5401AWW Dryer - Gas
Maytag SDG5401AXW Dryer - Gas
Maytag SDG5701AWQ Dryer - Gas
Maytag SDG5701AWW Dryer - Gas
Maytag SDG5701AXW Dryer - Gas
Whirlpool SDH481B0
Whirlpool SDH501B20
Amana SDI22A Ref - SXS/I&W
Amana SDI22A-A Ref - SXS/I&W
Amana SDI22A-AG Ref - SXS/I&W
Amana SDI22A-C Ref - SXS/I&W
Amana SDI22B Ref - SXS/I&W
Amana SDI22B-A Ref - SXS/I&W
Amana SDI22B-C Ref - SXS/I&W
Amana SDI22B-G Ref - SXS/I&W
Amana SDI22B-L Ref - SXS/I&W
Amana SDI22C Ref - SXS/I&W
Amana SDI22C-A Ref - SXS/I&W
Amana SDI22C-C Ref - SXS/I&W
Amana SDI22C-G Ref - SXS/I&W
Amana SDI22C-L Ref - SXS/I&W
Amana SDI22D Ref - SXS/I&W
Amana SDI22E Ref - SXS/I&W
Amana SDI22E-1-A Ref - SXS/I&W
Amana SDI22E-1-C Ref - SXS/I&W
Amana SDI22E-A Ref - SXS/I&W
Amana SDI22E-C Ref - SXS/I&W
Amana SDI22E-G Ref - SXS/I&W
Amana SDI22E-L Ref - SXS/I&W
Amana SDI22E1 Ref - SXS/I&W
Amana SDI22E1G Ref - SXS/I&W
Amana SDI22E1L Ref - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 Ref - SXS/I&W
Amana SDI22F-1-G Ref - SXS/I&W
Amana SDI22F-1-L Ref - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA Ref - SXS/I&W
Amana SDI22FC Ref - SXS/I&W
  #2 (permalink)
Old 06-16-2012, 03:15 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Does sound like the motor is overheating and tripping it's internal thermal protect.
Run it on air only to see if it still stops.
If it runs OK then my guess is that the hot air is being blown back onto the motor and heating it up. I would then check the exhaust/vent system.
If it still kicks out try rotating the drum in the correct direction. It should turn fairly easily. If not then it something is putting too much load on the motor causing it to overheat. Open it up and look for the cause re: rear support rollers, front glides, idler wheel, drum seals etc.
Also if it runs OK with no clothes but stops with clothes this is an indication of a drum mounting problem, usually bad front glides.
__________________
  #3 (permalink)
Old 06-16-2012, 10:42 AM
Junior Member
Default
I tried the dryer on the fluff cycle and it still shut off after 10 min. this time the tub was not warm. i also pulled the dryer out away from the wall to make the duct straight.
I have replaced the motor on this dryer is ther any other thermal protectors like a thermal fuse cycling thrmostat or high limit thermostat on this dryer that could be causing this problem
  #4 (permalink)
Old 06-16-2012, 02:39 PM
Senior Expert
APP Volunteer
Default
Here are your parts includes wiring diagrams
Replacement parts for Maytag SDE2606AYW DRYER- ELE | AppliancePartsPros.com
As you can see from the wiring diagram there is nothing in the motor circuit that will shut it off and then reset other than the thermal protect built into the motor.
If the drum does not have a lot of drag then the only thing I can think of is that your replacement motor is also bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer shuts off after 5-20 seconds davevet Dryer Repair 3 01-08-2011 03:34 PM
Maytag Electric Dryer Shuts Down walkthesky Dryer Repair 18 10-13-2010 09:45 AM
Maytag gas dryer lights but shuts off donschaller Dryer Repair 0 01-07-2010 06:26 PM
Maytag gas dryer starts and shuts off donschaller Dryer Repair 0 01-06-2010 06:28 PM
Maytag Gas Dryer - Gas shuts off after 10 MIN Bigt29 Dryer Repair 3 08-25-2009 09:39 AM
