Discuss
Maytag Performa PYE2000AYW Burning?
 in
Dryer Repair
My Maytag Performa PYE2000AYW suddenly stopped with a loud thud and a very strong burning smell was coming from it.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Performa PYE2000AYW Burning?
  #1 (permalink)
Old 06-12-2012, 06:08 PM
Junior Member
djune617 is on a distinguished road
Default Maytag Performa PYE2000AYW Burning?
Model Number: PYE2000AYW   Brand: Maytag   Age: 5 - 10 years
My Maytag Performa PYE2000AYW suddenly stopped with a loud thud and a very strong burning smell was coming from it. I quickly cut the power at the breaker box, unplugged it and removed the contents, which were dry. The lint trap was cleaned and I checked to make sure the duct was clear at both ends, which it was. I'm hesitant to power it back up. This unit is probably 10+ years old and the only repair I've ever had to do was to replace the fuse about 5 years ago. Is it worth trying to fix or time to go shopping? By the way, does the 2000 in the model number indicate year of manufacture?
Ads By Google
Related Models
Maytag PYE2000AYW Dryer - Ele
Maytag PYE2000AZW Dryer - Ele
International PYE2000GGE Dryer - Ele
International PYE2200AKW Dryer - Ele
Maytag PYE2200AYW Dryer - Ele
Maytag PYE2200AZW Dryer - Ele
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
  #2 (permalink)
Old 06-13-2012, 01:51 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram.
Replacement parts for Maytag PYE2000AYW DRYER- ELE | AppliancePartsPros.com
A lot depends on the type of burning smell.
If it smelled like plastic or electrical then odds are the motor was making the smell.
If it was like lint overheating then it may be a simpler fix, perhaps just a broken belt.
Try turning the drum by hand, it should turn fairly easily.
If not you will have to open it up and find out why.
Check the rear support rollers, the front support, the drum seals, the idler wheel, the motor etc.
My gut says that the motor probably seized as you did not hear anything unusual before it failed. The other items usually squeak or scrape before failing.
Depends on how good of shape it is in and are you happy with it.
The motor is approximately $175 so is an expensive item to replace butt still a lot less than a new unit. Also I would check what other parts have to be replaced to do a basic overhaul on it. No use replacing the motor if you have to open it up again in s couple months because the belt broke etc.
I do not think so. they made a whole2000 series of units with different options.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Rueben Oven Repair (including Ranges and Cooktops) 1 03-31-2011 07:33 AM
maytag performa korean1 Washer Repair 7 02-26-2011 06:41 AM
Maytag Performa geneawho Washer Repair 2 03-20-2010 05:45 PM
Performa Maytag helen0000 Washer Repair 3 09-14-2009 05:42 AM
Maytag Performa msskatemom Washer Repair 5 06-24-2009 10:30 AM
