I have a Whirlpool model LGR7620LWD. It will heat for about 30 minutes and then I lose heat. I took the drum out and watched as the unit heated and ran, but the flame stopped after half an hour. Next I unhooked the exhaust stack and ran it without one. Same issue. Then I took the back plate off the unit and checked the two thermostats which are next to each other. Both have continuity, even when it is not heating. How would you suggest I proceed?
Chuck
