Drum won't turn anymore. But feels like it is some kind of an electrical problem. On an automatic moisture drying setting, before it would quite, it would make a sound as if like a loose contact/faulty sensor - buzzer would start to signal and then quieten down for a minute or two before finally buzzing to stop.
With the door in the closed position, when I turn the timer dial, I start hearing the timer ticking sound. If I press the start button, if feels as if some action took place with a click but nothing starts working. If I press the start switch the 2nd time, no click sound - as if the start was already active. If I open the door, the timer ticking stops. Close the door, it starts again.
I have checked the following things:
- Checked dryer thermal fuse for continuity. Since I had a spare, replaced it - just in case. - Checked exhaust duct for being blocked. Was fine. - Checked High limit termostat for continuity - Check cycling thermostat for continuity - Checked door switch for continuity - Checked start button for continuity - it has 3 terminals and I could see that 2 of them would be connected to form the circuit when the button was pushed. And it did show continuity when pressed. - Drum belt is intact - I opened the top cover to visually inspect it. I can also rotate drum by hand. - One site mentioned checking the resistance across the 2 terminals of the timer motor - I forget the resistance # but the number generally matched the website. - Timer has 6 terminals. Across 2 of the leads, as I rotated the timer knob, the continuity changed from no-continuity to being continuous in one of the cycles. I left it that setting and tried to push start button, drum still didn't rotate.
If anybody can suggest few other things to test before I jettison the unit, it would be very much appreciated.
Bimal
