Dryer starts/heats ONLY when start button pressed
Model Number: LGB6200PQ0
REF: SER# MS4306735 TYPE:WJR-NAT-1206006-FM22 My basement flooded about foot high. The dryer was connected to AC oulet when this happened but not running/operating. I removed the standing water from inside the drum and let the dryer sit and dry out for 3 weeks before I even tried to start it. Now when I try to start the dryer the drum will turn, heat will be present until I release the start button. There are no different sounds or characteristics. I'm hoping to repair this unit as I have with my washer. Any and all help would be appreciated. Thanks. |
Most likely the problem is a bad motor main winding. The correction is to replace the motor.
- The motor Part number: 279827 Here are the breakdown diagrams and Replacement parts for Whirlpool LGB6200PQ0 29"GAS DRYER | AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 08:34 AM. |
