Emazing
#1 Posted : Wednesday, June 6, 2012 1:57:26 PM(UTC)
Emazing
Replaced the three coils worked for a month. Now all I get is a glow and No flame. Is it time to abandon fix and buy new? Help please.
#2 Posted : Thursday, June 7, 2012 1:43:51 PM(UTC)
How long time the igniter stays On (glows)?
Emazing
#3 Posted : Friday, June 8, 2012 11:36:31 AM(UTC)
Emazing
Hi Gene,
It glows for 20 seconds,then i can hear a click for when the flame should kick in ( but it does not) then it takes another 10 secs to shut off. After a bit the process repeats itself.
#4 Posted : Friday, June 8, 2012 3:24:49 PM(UTC)
Try to replace the flame sensor.
- The flame sensor Part number: 338906
Part number: 338906
Emazing
#5 Posted : Saturday, June 9, 2012 5:00:42 AM(UTC)
Emazing
Thanks Gene. The flame sensor checks out for continuity, however the white wire connector seems a bit loose. Could this be the problem? If I order a new part will the white wire connector fit better?:confused:
Emazing
#6 Posted : Saturday, June 9, 2012 9:09:34 AM(UTC)
Emazing
Nope not that, I repaired the connector...still no flame , will try replacing the flame sensor
Emazing
#7 Posted : Saturday, June 16, 2012 9:06:11 AM(UTC)
Emazing
I give ....time to replace.
#8 Posted : Saturday, June 16, 2012 4:41:06 PM(UTC)
It can be a bad gas valve but it's not worth to replace it. Too much $$$
gas dryer no flame (Dryer Repair)
by stargate1 6/12/2011 11:47:06 AM(UTC)
gas dryer no flame how chek cycling thermst (Dryer Repair)
by tinkernfix 12/6/2008 8:56:39 AM(UTC)
Gas Dryer no flame (Dryer Repair)
by Jimbeau 3/1/2008 9:58:08 AM(UTC)
