Discuss
Main circuit breaker keeps tripping
 in
Dryer Repair
When my dryer heats up, the top gets very hot and the main circuit breaker trips. If I use the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Main circuit breaker keeps tripping
  #1 (permalink)
Old 06-05-2012, 08:00 PM
Junior Member
wing63 is on a distinguished road
Default Main circuit breaker keeps tripping
Model Number: LEQ9508PWO   Brand: Whirlpool   Age: 5 - 10 years
When my dryer heats up, the top gets very hot and the main circuit breaker trips. If I use the dryer with air only (no heat) it runs just fine. I have narrowed it down the the themal cut-off switches or the blower thermostat. Anyone help as to which one would cause the breaker to trip.
Ads By Google
Related Models
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
  #2 (permalink)
Old 06-06-2012, 03:34 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool LEQ9508PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
I doubt it is a thermostat because it has not blown a thermal cut-off or fuse.
But you did not say how you diagnosed it as a thermostat.
A more likely cause culprit is the heating coil being grounded.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and draw too much current.
It would also be a good idea to check/clean your vent system.
Also check/clean the blower wheel.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
error code f09&tripping circuit breaker yirga29 Washer Repair 1 02-10-2011 06:26 PM
Sears gas dryer tripping circuit breaker dwawayne Dryer Repair 1 01-14-2011 09:17 PM
circuit breaker tripping laretta Refrigerator & Freezer Repair 2 05-10-2010 07:25 AM
tripping the breaker chefmango Dryer Repair 6 05-17-2009 09:02 AM
Range tripping circuit breaker, but only intermittently AlloyGT Oven Repair (including Ranges and Cooktops) 4 11-28-2008 05:00 AM
