| » Duet GE9200 wont start drying |
Model Number: GE9200 Brand: Whirlpool Age: 1 - 5 years
All lights are lit. The diagnostic test has everything beeping. After reading some other posts I purchased a replacement door switch. This replaced but I have the same problem. When the start button is held you here a click but the dryer does not start.
What part do I need to replace next? Ads By Google Related Models |
HI.
Please provide the complete model number of the unit. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
You should check three things: -thermal fuse #59 on diagr.#1 -belt -broken belt switch #5, diag.#2 Here are the breakdown diagrams and Replacement parts for Whirlpool GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
The thermal fuse us fine tge belt is connected the belt switch i put a tone on it when it is depressed the switch is open and when it is up there is continuity between the poles. Not sure if that proves anything about the switch. now tgat i have the thing completely dismantled anything else i can check? Let me know if you think i should replace the belt switch.
I took the control panel off and under the part which is labeled motor i see a black solder which is burned out i suppose. I can replace the control panel but caused that relay or whatever it is to burn out.
HI.
Solder this connection. Good chance it will take care of the problem. Simon.
__________________
| Display Modes | |
| whirlpool duet gas dryer wont start | doverf | Dryer Repair | 5 | 12-06-2011 11:51 AM |
| Whirpool Duet Washer wont start | smooothopr | Washer Repair | 2 | 06-08-2011 09:54 PM |
| Whirlpool duet wont start when start button is pushed | happymom | Washer Repair | 1 | 02-02-2011 07:28 AM |
| Start Button Wont Work On Duet Washer | mmcghee | Washer Repair | 1 | 08-29-2009 04:39 AM |
| Whirlpool Duet Sport Dryer wont start | Jstout | Dryer Repair | 4 | 08-20-2008 01:11 PM |
