| » dryer |
Model Number: 11086427110 Brand: Kenmore Age: More than 10 years
Hello I have a kenmore dryer not getting hot vent is good thanks with your help simon
Hi.
Do you mean there is no heat at all or just not hot enough? You will need the multimeter to troubleshoot. If no heat check the continuity of the: heater, thermal cut-off, hi-limit and cycling thermostat. When checking - unplug the dryer. The access to all this parts is from the back (you need to remove the rear panel). When checking the continuity take off one wire from the contact. The heater Part number: 4391960 The hi-limit kit Part number: 279769 The cycling thermostat Part number: 694674 Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
