when checking for continuity on the safety thermostat (with a cheap light tester) if the tester light is weak or doesn't light every time could this be the part that's bad?? also the part has four connectors two light dimly when connected to the tester the other two not at all. The two connectors that are wide set on the part the light will come on dimly. The two connectors set close together when you test them won't light at all. Thanks Kelly
Here are your parts Replacement parts for General Electric DBXR463EB1WW Electric dryer | AppliancePartsPros.comIf you are checking Item 230 in Section 1 then it is the main control thermostat and not a safety thermostat. First In would get yourself a meter. The tester you are using in my opinion are useless. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
