No heat. continuity on hi-limit thermostat and thermal fuse reads at 0. continuity on element reads 1. My ohm meter reads 1 when not hooked up to anything. Is there anything else I should check or does this mean that the element needs replaced?
Groups: APP Team
Hi. It sounds like the heating element is gone. Just to make sure remove it and do the visual. The heating element Part number: 3387747
