Clothes Sopping Wet, Dryer Will Heat And Run Fine Until Cloths Are Damp ,then It Will Tumble With No Heat At All Nomatter What Dry Mode Is Used.gas Dryer Will Only Heat If Clothes Are Saoking Wet But Will Just Tumble Cold When About 3/4 Dry.is This Bad Dryness Sensor Or ? Thanks Brian
