Discuss
Rear Bearing replacement
 in
Dryer Repair
Squeaky rear drum bearing needs replaced on Frigidaire all in one model number FEX831CS0. Can anyone give me directions on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Rear Bearing replacement
  #1 (permalink)
Old 09-11-2009, 09:53 AM
Junior Member
Randy Adams is on a distinguished road
Default Rear Bearing replacement
Model Number: FEX831CS0   Brand: Frigidaire   Age: 1 - 5 years
Squeaky rear drum bearing needs replaced on Frigidaire all in one model number FEX831CS0. Can anyone give me directions on taking it apart?
Ads By Google
Related Models
Frigidaire FEX831CS0 Frigidaire/laundry Center
Frigidaire FEX831FS0 Frigidaire/laundry Center
Frigidaire FEX831FS1 LAUNDRY CENTER
Frigidaire FEX831FS2 LAUNDRY CENTER
Frigidaire FEX831FS4 LAUNDRY CENTER
Frigidaire FEZ831AS0 Lc - Frigidaire
Frigidaire FEZ831AS1 Lc - Frigidaire
Frigidaire FEZ831AS2 Frigidaire/laundry Center
Frigidaire FEZ831CFS0 Frigidaire/laundry Center
Frigidaire FEZ831CFS1 LAUNDRY CENTER
Amana FF105 REF - BOTTOM MOUNTS
Amana FF105A REF - BOTTOM MOUNTS
Amana FF105B REF - BOTTOM MOUNTS
Amana FF105L REF - BOTTOM MOUNTS
Amana FF105LA REF - BOTTOM MOUNTS
Amana FF105LB REF - BOTTOM MOUNTS
Amana FF125 REF - BOTTOM MOUNTS
Amana FF125A REF - BOTTOM MOUNTS
Amana FF125B REF - BOTTOM MOUNTS
Amana FF125L REF - BOTTOM MOUNTS
Amana FF125LA REF - BOTTOM MOUNTS
Amana FF125LB REF - BOTTOM MOUNTS
Amana FF15 FREEZER- VERTICAL
General Electric FF16DSARWH Refrigerator
General Electric FF16DSBRWH Refrigerator
General Electric FF16DSCRWH Refrigerator
General Electric FF16DSDRWH Refrigerator
General Electric FF16DSERWH Refrigerator
General Electric FF16DXARWH Refrigerator
General Electric FF16DXBRWH Refrigerator
General Electric FF16DXCRWH Refrigerator
General Electric FF20DSARWH Refrigerator
General Electric FF20DSBRWH Refrigerator
General Electric FF20DSCRWH Refrigerator
General Electric FF20DSDRWH Refrigerator
General Electric FF20DSERWH Freezers
General Electric FF20DXARWH Refrigerator
General Electric FF20DXBRWH Refrigerator
General Electric FF20DXCRWH Refrigerator
Amana FF98 REF - BOTTOM MOUNTS
Amana FF98A REF - BOTTOM MOUNTS
Amana FF98B REF - BOTTOM MOUNTS
Amana FF98L REF - BOTTOM MOUNTS
Amana FF98LA REF - BOTTOM MOUNTS
Amana FF98LB REF - BOTTOM MOUNTS
Frigidaire FFBD1821MB0A DISHWASHER
Frigidaire FFBD1821MS0A DISHWASHER
Frigidaire FFBD1821MW0A DISHWASHER
Frigidaire FFBD2403LB0A DISHWASHER
Frigidaire FFBD2403LB0B DISHWASHER
Frigidaire FFBD2403LS0B DISHWASHER
Frigidaire FFBD2403LW0A DISHWASHER
Frigidaire FFBD2403LW0B DISHWASHER
Frigidaire FFBD2405KB0 DISHWASHER
Frigidaire FFBD2405KB0A DISHWASHER
Frigidaire FFBD2405KS0 DISHWASHER
Frigidaire FFBD2405KS0A DISHWASHER
Frigidaire FFBD2405KW0 DISHWASHER
Frigidaire FFBD2405KW0A DISHWASHER
Frigidaire FFBD2407LB0A DISHWASHER
Frigidaire FFBD2407LB0B DISHWASHER
Frigidaire FFBD2407LM0A DISHWASHER
Frigidaire FFBD2407LM0B DISHWASHER
Frigidaire FFBD2407LQ0A DISHWASHER
Frigidaire FFBD2407LQ0B DISHWASHER
Frigidaire FFBD2407LS0A DISHWASHER
Frigidaire FFBD2407LS0B DISHWASHER
Frigidaire FFBD2407LW0A DISHWASHER
Frigidaire FFBD2407LW0B DISHWASHER
Frigidaire FFBD2409LB0A DISHWASHER
Frigidaire FFBD2409LM0A DISHWASHER
Frigidaire FFBD2409LQ0A DISHWASHER
Frigidaire FFBD2409LS0A DISHWASHER
Frigidaire FFBD2409LW0A DISHWASHER
Frigidaire FFC04M0AW1 Frigidaire/freezer
Frigidaire FFC0513D Frigidaire/freezer
Frigidaire FFC0522DW0 Frigidaire/freezer
Frigidaire FFC0522DW1 Frigidaire/freezer
Frigidaire FFC0522DW10 FREEZER
Frigidaire FFC0522DW11 FREEZER
Frigidaire FFC0522DW12 FREEZER
Frigidaire FFC0522DW13 FREEZER
Frigidaire FFC0522DW14 FREEZER
Frigidaire FFC0522DW15 FREEZER
Frigidaire FFC0522DW16 FREEZER
Frigidaire FFC0522DW17 FREEZER
Frigidaire FFC0522DW18 FREEZER
Frigidaire FFC0522DW19 FREEZER
Frigidaire FFC0522DW2 Frigidaire/freezer
Frigidaire FFC0522DW20 FREEZER
Frigidaire FFC0522DW3 Frigidaire/freezer
Frigidaire FFC0522DW4 Frigidaire/freezer
Frigidaire FFC0522DW5 Frigidaire/freezer
Frigidaire FFC0522DW6 Frigidaire/freezer
Frigidaire FFC0522DW7 FREEZER
Frigidaire FFC0522DW8 FREEZER
Frigidaire FFC0522DW9 FREEZER
Frigidaire FFC0522FW0 Frigidaire/freezer
Frigidaire FFC0522FW1 FREEZER
Frigidaire FFC0522FW2 FREEZER
Frigidaire FFC0522FW3 FREEZER
Frigidaire FFC0522FW4 FREEZER
Frigidaire FFC0522FW5 FREEZER
Frigidaire FFC0522FW6 FREEZER
Frigidaire FFC0522FW7 FREEZER
Frigidaire FFC0522FW8 FREEZER
Frigidaire FFC0522FW9 FREEZER
Frigidaire FFC0522GB0 Frigidaire/freezer
Frigidaire FFC0522GB1 FREEZER
Frigidaire FFC0522GB5 FREEZER
Frigidaire FFC0523DW0 Frigidaire/freezer
Frigidaire FFC0523DW1 Frigidaire/freezer
Frigidaire FFC05C2AW0 Frigidaire/freezer
Frigidaire FFC05C2AW1 Frigidaire/freezer
Frigidaire FFC05C3CW0 Frigidaire/freezer
Frigidaire FFC05C3CW1 Frigidaire/freezer
Frigidaire FFC05C3CW2 Frigidaire/freezer
Frigidaire FFC05C3CW3 Frigidaire/freezer
Frigidaire FFC05C4CW0 Frigidaire/freezer
Frigidaire FFC05K0AW0 Frigidaire/freezer
  #2 (permalink)
Old 09-11-2009, 01:40 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
You will take off the front access panel, console and front panel. Then take off the top, release the belt from the rear access panel and lift the drum up to release it from the plastic bracket. The drum will then come out the front and you have access to the bearing.
Here is the service manual.
http://frigidaireservicetips.com/pdfs/488_3.pdf
I would order the kit and replace all the parts, plus you get a lubricant in the kit.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rear bearing replacement - Frigidaire jhicks Washer Repair 2 02-22-2010 05:31 PM
Frigidaire rear bearing replacement Irontrader Dryer Repair 1 02-06-2010 11:17 AM
Rear Bearing Lawrence00 Dryer Repair 2 11-10-2009 02:59 PM
rear bearing linus410 Dryer Repair 1 09-18-2009 10:01 PM
Rear Tub Bearing Justncase Washer Repair 5 08-08-2007 09:54 PM
