tlksr98
#1 Posted : Friday, September 11, 2009 7:28:41 AM(UTC)
tlksr98
Can someone please help,. I have a kenmore dryer that has stop blowing heat, everything works except it won't dry our cloths after looking at the different blogs I've learned of the possible heating elements that could be the cause. I've checked the Thermal fuse, (AP3132867),. and the Thermal Cut Off,. (AP30942243), for continuity and they both seem to be ok,. also as suggested in the blogs there is no heater box on the the dryer, I don't think mines has one so it must have something to do with the igniter or the blower however I don't know how to check those things, can you please help.
Terry
manks
#2 Posted : Saturday, September 12, 2009 3:54:14 AM(UTC)
manks
I have the same problem right now, it is generally one of three things, thermostat, heating coil of a fuse. You have to check each of these. I am about to try, but do not know how to get the back plate off the dryer.
Dryer won't blow heat (Dryer Repair)
by pdiddy69 2/13/2011 1:13:00 PM(UTC)
Dryer Won't Blow Heat (Dryer Repair)
by sbechard 7/16/2008 3:33:34 PM(UTC)
