| » Banging noise when drum spins |
Model Number: LE4900XMW1 Brand: Whirlpool Age: More than 10 years
Hello. I have a WHIRLPOOL LE4900XMW1. The dryer is making funny thumpinging-type noises when it spins, like there's some sort of loose piece behind the drum. It started after I had to move the dryer and tilt it back and forth to put the wheels back on it (two had popped out) - I don't know if that's a coincidence or not. I know nothing is caught down behind the dryer vent area, so I'm only assuming that there's something else loose. It will heat up, but I'm afraid to run it until the noise issue is resolved.
I've replaced the power cord before on this dryer, so I figured I'd pull the back cover off and see whether anything is loose or hanging. Any ideas of what specifically to look for? Thanks. Ads By Google Related Models |
Replacement parts for WHIRLPOOL LE4900XMW1 | AppliancePartsPros.com Often banging is due to bad rear support rollers. See Item 35 in Section 3
__________________
Quote:
Sure sounds like a roller issue. Especially if that thump is rhythmic. See if one of them may have a flat spot it.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hello. I've checked both roller wheels. each one is smooth and shaped as it should be. Do you have any other suggestions of what I should check? Thank you so much for your help, it is appreciated.
| Display Modes | |
| banging noise in spin cycle | wildlilly | Washer Repair | 4 | 03-22-2010 08:32 PM |
| Loud banging noise during spin | willimom | Washer Repair | 1 | 02-02-2010 04:30 PM |
| Front load makes banging noise | cmatheso | Washer Repair | 0 | 09-20-2008 09:27 AM |
| My washer is banging loudly when it spins | Cam2008 | Washer Repair | 1 | 07-30-2008 03:32 PM |
| dryer drum banging noise | a2home | Dryer Repair | 1 | 10-12-2007 02:14 AM |
