Discuss
Dryer not stopping in automatic mode
 in
Dryer Repair
This gas dryer works fine in timed modes, but in automatic mode I've had this problem for a while
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not stopping in automatic mode
  #1 (permalink)
Old 01-24-2008, 08:57 AM
nwright98 nwright98 is offline
Junior Member
nwright98 is on a distinguished road
Default Dryer not stopping in automatic mode
Model Number: ALE866SAW   Brand: Amana   Age: 5 - 10 years
This gas dryer works fine in timed modes, but in automatic mode I've had this problem for a while and haven't been able to resolve it. The dryer will start and run normally, but occasionally the timer will never advance to cool down and will continue to run (and heat) until you turn it off.
I found the service manual at:
http://www.servicematters.com/maytag...S3200007R0.pdf
My problem appears to match up with #14 in the troubleshooting procedures. To date I've done or replaced the following (in this order):
- Removed & cleaned duct / wall vent.
- Checked continuity and operation of moisture sensor.
- Replaced timer.
- Replaced moisture sensor control board.
- Removed moisture sensor bars, cleaned them and plastic air duct assembly where they mount.
- Checked / cleaned door seal.
- Checked cycling thermostat and thermostat heater, heater resistance was low (1500 ohms) so I replaced both with the new 1-piece thermostat/heater assembly.
So far none of this has made any difference on the problem. I also used to occasionally experience a problem where the dryer would run but not heat so the clothes were wet at the end of the cycle (but the cycle would end on it's own.) I haven't seen that problem in a while, so one of the replaced components probably fixed that issue.
Can anyone offer any advice on what I should check next? The dryer's in great condition other than this and I can run it in timed mode but I'd like to have everything working.
Thanks,
Nick Wright
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-24-2008, 09:30 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
does dryer take longer than normal to dry in time cycle ? have you tried running a load of clothes in the automatic cycle with vent off of dryer ?
__________________
regards
jim
  #3 (permalink)
Old 01-24-2008, 09:55 AM
Junior Member
Default
No, the amount of time seems consistent with what it's always taken, approx. 40-50 minutes for an average load.
Thanks,
Nick
  #4 (permalink)
Old 01-24-2008, 10:21 AM
Senior Expert
APP Volunteer
Default
tried running a load w/ vent off of dryer ?
__________________
regards
jim
  #5 (permalink)
Old 01-24-2008, 11:03 AM
Junior Member
Default
Not yet, I'll give it a try. What will that tell me? The vent pipe's only about 5' long and I've pulled it off and cleaned it and the damper in the wall.
  #6 (permalink)
Old 01-25-2008, 07:24 AM
Senior Expert
APP Volunteer
Default
Sorry , my mistake, should have asked how long the vent was... 5 foot long is not going to make much of a difference ... what happens when you tape a piece of wire across the two sensor bars together ? ( in auto cycle )
__________________
regards
jim
  #7 (permalink)
Old 01-25-2008, 11:53 AM
Junior Member
Default
I tried it with the vent disconnected last night, it didn't make a difference in the operation.
I've tested the contacts per the service manual by taping a piece of metal across them. I get 3 beeps shortly after starting the cycle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Never stopping dishwasher John Emery Dishwasher Repair 4 01-27-2008 10:02 AM
maytag dryer keeps stopping/turning off mymoolahsgone Dryer Repair 1 12-06-2007 04:44 PM
Automatic washer Gary Washer Repair 1 08-30-2007 03:36 PM
Dryer keeps stopping after 20 minutes dsbell Dryer Repair 1 08-20-2007 12:33 PM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 12:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
