Discuss
Estate Electric Dryer - No Heat
 in
Dryer Repair
My Estate electric dryer stop making heat this morning. I've reviewed your forums and checked what I could be I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Estate Electric Dryer - No Heat
  #1 (permalink)
Old 05-26-2012, 02:47 PM
Junior Member
Porkface is on a distinguished road
Default Estate Electric Dryer - No Heat
Model Number: TEDL660WNO   Brand: Estate   Age: More than 10 years
My Estate electric dryer stop making heat this morning. I've reviewed your forums and checked what I could be I have a couple questions.
Thermal Fuse reads 0.4 ohms with meter set at 200 ohms.
Heating Coil reads 10.2 ohms and no resistance when grounding each terminal to case.
Internal Bias thermostat (cycling thermostat) reads 0.2 ohms on outside terminal (heavier red wires) and 7230 ohms (7.23 at 20k ohms) on inner terminals (purple and white wires).
Thermal Cut-Off produces no reading (open?).
High Limit Thermostat fell apart when removing connectors. Connector on one side is scorched and insulation missing on first inch of wire. Next inch of insulation is scorched.
Obviously the High Limit Thermostat needs to be replaced. I'm uncertain about the Thermal Cut-Off but assume it should be replaced too.
I think I can reroute the scorched wire and remove the damaged portion.
Can you suggest other reasons the wire is scorched? Anything else I should check?
Ads By Google
Related Models
Whirlpool TEDL660WW0
Whirlpool TEDL680AN0
Whirlpool TEDL680AW0
Whirlpool TEDS680BN0
Whirlpool TEDS680BN1
Whirlpool TEDS680BN2
Whirlpool TEDS680BQ1
Whirlpool TEDS680BQ2
Whirlpool TEDS680BW0
Whirlpool TEDS680BW1
Whirlpool TEDS680BW2
Whirlpool TEDS680DQ0
Whirlpool TEDS680DQ1
Whirlpool TEDS680EQ0
Whirlpool TEDS680EQ1
Whirlpool TEDS680EQ2
Whirlpool TEDS740JQ0
Whirlpool TEDS740JQ1
Whirlpool TEDS740JQ2 29"electric Dryer
Whirlpool TEDS740PQ0 29"electric Dryer
Whirlpool TEDS740PQ1 29"electric Dryer
Whirlpool TEDS780JQ0
Whirlpool TEDS840JQ0
Whirlpool TEDS840JQ1
Whirlpool TEDS840JQ2
Whirlpool TEDS840JQ3 29"electric Dryer
Whirlpool TEDS840PQ0 29"electric Dryer
Whirlpool TEDS840PQ1 29"electric Dryer
Whirlpool TEDX340RW0 29" Electric Dryer
Whirlpool TEDX340RW1 29" Electric Dryer
Whirlpool TEDX340RW2 29" Electric Dryer
Whirlpool TEDX540RQ0 29" Electric Dryer
Whirlpool TEDX540RQ1 29" Electric Dryer
Whirlpool TEDX640EQ0
Whirlpool TEDX640EQ1
Whirlpool TEDX640EQ2
Whirlpool TEDX640JQ0
Whirlpool TEDX640JQ1
Whirlpool TEDX640JQ2 29"electric Dryer
Whirlpool TEDX640PQ0 29" Electric Dryer
Whirlpool TEDX640PQ1 29"electric Dryer
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FSA Tappan/range
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
  #2 (permalink)
Old 05-27-2012, 12:36 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts. looks like a lot of the unit is missing. AppliancePartsPros probably sells the parts but for some reason the parts breakdown is incomplete.
Replacement parts for TEDL660WNO models | AppliancePartsPros.com
Yes both the thermal-cut off and hi-limit should be replaced.
The wire that is bad will have to be cut back till you get to nice clean copper.
Then a new high current connector will have to be crimped to it.
Could be that there was a bad connection at the high-limit from day one. This is then a resistance and it heats up when current passes through it. This then further degrades the connection causing more heat and so on and so on till the connection fails.
I would check a couple other things just in case.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate(Whirlpool) Electric Dryer not heating JDB59 Dryer Repair 11 12-10-2012 12:07 PM
Estate by Whirlpool Electric Dryer barbanns Dryer Repair 1 08-20-2011 06:16 AM
Whirlpool Estate Electric Dryer Jefnir Dryer Repair 3 06-17-2011 02:22 AM
estate electric dryer lloyd51 Dryer Repair 0 03-27-2011 03:20 PM
Estate whirlpool electric dryer CAYCE Dryer Repair 1 07-26-2009 05:17 PM
