I have a Kenmore Gas Dryer, 80 Series, Model: 11076814694 that while running will occasionally quit heating. If I unplug it and let it sit a while, it will work again. What part or parts do I need to repair this? Thank you.
Hi, You will want to make sure the inside of the dryer around the blower housing and the dry duct is clear of any lint build up first. The I would suspect the gas valve coils need to be change, Part number: 279834
