Hi, when I pull the timer knob to start the dryer I have to hold it out to work. If I release it, the machine shorts and stops working. I took the panel apart and opened the dryer timer. There were loose parts in it, the black small wheel and some clear plastic parts. I ordered that piece. Do you think that is the solution to the problem. Thanks
