When you try to start the dryer, it makes a click and then beeps like you have paused it. I checked the close door button, and it is working the light goes on and off as normal. All lights are working so I assume it has power. I unplugged it and plugged it back in. Nothing...yesterday it did it once and then worked for a minute, now doing it again, any suggestions?
Groups: APP Team
HI.
Slowly rotate the selector knob to a different setting and try to start. What is displayed in the LED screen if you wait for a few minutes? Check the belt, belt tension switch, door switch with multimeter.
Post the results.
Simon.
