This is a "stackable" unit; dryer will not start. Replaced the start switch and timer and it still will not start. Anything else I could be missing? I don't have the wiring diagram...
Groups: APP Team
Hi. Check the thermal limiter (fuse)#36 on the diagram#2 most likely it's open. Clean the air ducts inside and outside the dryer. The limiter Part number: 134120900
I'll try that and I will post the results. Thanks very much.
Groups: APP Team
Originally Posted by: Simon / APP Team You are welcome.
Simon. Quick question? What's the easiest way to access/change the limiter? Remove back panel or can I access it by removing the top panel? Got the part and I'm going to replace it (try) today.
Groups: APP Team
Hi.
You should be able to get to it from the top.
Simon.
