How do you access gas coils for replacement on Frig. Affinity dryer
Groups: APP Team
Hi.
Here are the instructions : - Unplug the dryer. - Remove two screws at the back holding the top.Slide it 1/2" back and lift off. - Take out four screws and remove the console. - Remove two screws out on each side at the bottom holding the front panel to the bodysides. - Raise the front of the dryer and remove two screws holding the bottom of front panel to the base. - Pull out on the bottom of the front panel to release the spring loaded tabs. - Lift up on the front panel to release two tabs at the top and swing the panel out. - Disconnect wiring. - Take two screws out, lift the metal bracket off, remove and replace the coils. - Reassemble the dryer.
Thank you. Post the results.
Simon.
