The drum on my dryer stopped turning,when you try start the dryer the motor hums but drum not turning.If you hold the on button in for roughly 5 seconds the dryer sounds like it trips out,guess a safety feature.Have already changed the motor and belt.The drum rollers seem okay they turn normally without drum on and when rotating drum counter clockwise to make sure drum is sat right there is no problem.Any help would be much appreciated.
Found the problem and is working fine now.Liquid must have gotten into the filter compartment,there was a solid build up of lint in the blower wheel stopping it from turning.
