Discuss
No Heat on Gas Dryer
 in
Dryer Repair
...Is it safe to jumper around the flame sensor to be sure its bad?... You can do it only to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat on Gas Dryer
  #21 (permalink)
Old 11-11-2009, 03:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can do it only to see if the burner would light up. You have to stop the dryer right away (just open the door).
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 11-11-2009, 07:51 PM
Junior Member
c22jrc is on a distinguished road
Default
Thanks again! I did double check my readings and ordered the part.
It has all ready been shipped. The local parts supplier was more expensive
and would have had to the order the part too.
  #23 (permalink)
Old 11-12-2009, 03:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #24 (permalink)
Old 11-19-2009, 08:04 AM
Junior Member
Hadi4us is on a distinguished road
Default
Hello Gene,
I am having similar issue with my gas dryer ( Kenmore 90 series).
I went thru the above check list, every item was checked ok with multimeter. One thing that I learned to get the heat working is to open/close the door when is running until it stop completely as I press the start button. Once it stop, I repress the start button again then everything is running as normal for few days. Does this make sense? I had cleanned the entire dryer including all contacts. Any other recommendation?
  #25 (permalink)
Old 11-19-2009, 08:05 AM
Junior Member
Default Kenmore - Gas Dryer running without HEAT
Hello Gene,
  #26 (permalink)
Old 11-19-2009, 05:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the dryer?
__________________
  #27 (permalink)
Old 11-20-2009, 05:55 PM
Junior Member
Default
Quote:
The model number is 100.78942892
Hadi
  #28 (permalink)
Old 11-24-2009, 09:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hadi,
Sorry for the delay.
Very likely the problem is a bad heat relay. It is located inside the control panel. There are two identical relays (#37 & #47 on the diagram), one for motor and the other one for heat. I can not tell exactly which one where goes without the wiring diagram.
- The relay Part number: AP3037419
__________________
  #29 (permalink)
Old 11-25-2009, 01:00 AM
Junior Member
Default
Gene,
No worry about the delay.
The heat relay could start to make sense.
I have been taking one of the connector off from the start switch button to stop the cycle. Once it stop I reconnect it back and press the start button again to get the dryer operate and it work fine for few days.
Is it away to test the relay or could it be my start button switch gets stuck sometimes? obviously these things can be fixed. if it's relay, can I just buy one and exchange #47 first to see if that do the trick?
Hadi
  #30 (permalink)
Old 11-25-2009, 09:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hadi,
You can find which relay is for heat by tracking the wires from the relays. Also look for a wiring diagram inside the control panel.
Possible the start switch is bad as well.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 01:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 05:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 10:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 07:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
