Discuss
No Heat on Gas Dryer
 in
Dryer Repair
I am not sure it was originally electric. We got it second-hand. I'm just going by the sticker on the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat on Gas Dryer
  #191 (permalink)
Old 01-03-2018, 06:58 AM
Junior Member
Hurtle is on a distinguished road
Default
I am not sure it was originally electric. We got it second-hand. I'm just going by the sticker on the door I told you about.
  #192 (permalink)
Old 01-03-2018, 02:24 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It sounds like it was converted from natural gas to propane. ?
  #193 (permalink)
Old 01-03-2018, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Let's start it over. Did you perform any tests using the wiring diagram I posted for you?
If you did, what exactly did you do?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #194 (permalink)
Old 01-04-2018, 09:47 AM
Junior Member
Default
I checked continuity between the places that should be closed in the circuit of the timer and the Start button. Everything seems good, but I can't check everything with the tools I have at hand. I tried to use my chinsy meter to get a reading on the AC coming in from the cord, but I don't know if its right because I got nothing at the distribution.
I tried putting the old fuse back inline, but still nothing.
that's what I've done.
  #195 (permalink)
Old 01-05-2018, 09:34 AM
Junior Member
Default
Alright, finally got to it. It was the outlet. There was power and the cord was good, but the contacts int he outlet were loose, creating a poor connection.
Thank you all for your time and concern. I really appreciate you all and this forum.
Merry Christmass!
  #196 (permalink)
Old 01-05-2018, 12:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are glad you were able to diagnose and fix the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 01:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 05:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 10:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 07:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
