Discuss
No Heat on Gas Dryer
 in
Dryer Repair
It's a Whirlpool LGR5634AWO
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat on Gas Dryer
  #11 (permalink)
Old 08-19-2009, 06:45 AM
Junior Member
tom_mn is on a distinguished road
Default dryer model
  #12 (permalink)
Old 08-19-2009, 11:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is check the gas valve coils as described in one of our previous posts: dryer runs but no heat
- The coil kit Part number: AP3094251
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR5634AW0 | AppliancePartsPros.com
Here are the wiring diagrams.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 08-22-2009, 10:09 AM
Junior Member
Default
Gene:
I located the coils with some difficulty and they tested this way:
2 prong: 1100
3 prong: 1050 and 1600
I don't really trust the analog ohmmeter even though I zeroed it out.
I tested the thermal fuse and it is shot, so I will order one of those, along with a thromostat.
  #14 (permalink)
Old 08-22-2009, 09:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep us posted.
__________________
  #15 (permalink)
Old 08-23-2009, 06:24 PM
Junior Member
Default
I replaced the thermal fuse and everything seems to run fine. I cleaned about a full paper grocery bag full of lint out of the exhaust system (about 14 ft long). Now when the dryer runs the outside flue flap pops all the way open. Before it only opened about half way when the dryer ran.
Hope that is the end of the problem. We don't really use the dryer much except in the winter so it won't be till then when it gets a lot of use that I know for sure the trouble is over.
  #16 (permalink)
Old 11-01-2009, 10:00 AM
Junior Member
clayn is on a distinguished road
Default
Gene,
I have the same problem with a GE gas dryer 1 yr old model# DSXH43GF1WW. The parts diagragms don't show where the Thermal fuse is located or what it looks like. They also don't show what the flame sensor looks like. I can do all of the continuity checks, but I want to know what to take apart first and what to look for. Any Advise or part numbers would be appreciated. Thanks
  #17 (permalink)
Old 11-01-2009, 10:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by clayn View Post
Gene,
I have the same problem with a GE gas dryer 1 yr old model# DSXH43GF1WW. The parts diagrams don't show where the Thermal fuse is located or what it looks like. They also don't show what the flame sensor looks like. I can do all of the continuity checks, but I want to know what to take apart first and what to look for. Any Advise or part numbers would be appreciated. Thanks
The thermal fuse (aka a safety thermostat) is shown as #1233 on the diagram #2. The flame sensor is shown as #1379 on the diagram #1.
- The safety thermostat Part number: AP3418852
Here are the breakdown diagrams and Replacement parts for GE DSXH43GF0WW | AppliancePartsPros.com
__________________
  #18 (permalink)
Old 11-10-2009, 05:07 PM
Junior Member
c22jrc is on a distinguished road
Default LGR7646eq0 No Heat
Glad to find this site!
I'm having the same problem. I've checked the coils, safety fuse both thermostats and all appear good. I measured resistance on the flame sensor at 680 ohms and the igniter at 94 ohms. I checked the voltage at the igniter and it only measured 28 volts. Tracing the wire it came from the motor. Wish I had a schematic!!! As someone else mentioned the timer does not move. The dryer had been running for at least 30 min. we I found there was no heat and the timer had not moved???
Any help greatly appreciated!!!
Jeff
  #19 (permalink)
Old 11-10-2009, 06:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...measured resistance on the flame sensor at 680 ohms...
Jeff,
If you did it the right way (removed at least one wire from the sensor) then the flame sensor is the culprit. Normal reading should be close to 0 Ohms.
- The flame sensor Part number: AP2910747
Here is the Wiring sheet for the dryer.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGR7646EQ0 | AppliancePartsPros.com
__________________
  #20 (permalink)
Old 11-10-2009, 06:51 PM
Junior Member
Default Gas Dryer no heat
Gene,
WOW such service!! Thanks for the schematic!
Is it safe to jumper around the flame sensor to be sure its bad?
Thanks Agian !!!!
Quote:
Originally Posted by Gene View Post
Jeff,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
