Removing Top Bosch Nexxt - HOW!
Brand: Bosch Age: 5 - 10 years
I need to remove the back panel of my Bosch Nexxt electric dryer to replace the high temp control but can't get the top off. You need the top off to get to the last two screws holding the back on. I removed the front quarter section of the top where the controls are located. I can see the inside of the dryer but the larger rearward top section is being held down by white nylon pegs. I can't figure out how to get the rest of the top disconnected from the nylon pegs. Frustrated! How do you disconnect the top from the pegs? Hours on google and youtube haven't helped.
Your help is appreciated!
Mike
Ads By Google
