| » replaced motor ran 2 weeks and stopped |
Model Number: lgc6646aq0 Brand: Whirlpool Age: 1 - 5 years
per your advice replaced motor 2 weeks ago......ran like a champ....then i was doing a load....heard the buzzer.....emptied and reloaded.....went to start and nothing.....unplugged an replugged....nothing......have let it sit for 2 hours still nothing
Have you tried to turn the drum manually like you did it with the old motor?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You have to have a simple multimeter in order to test a few parts.
The first thing I would do is check for 120 VAC at the wall outlet. Check the door switch for continuity. Open the control panel. Remove the wires from the push button start switch and check for 120 VAC between the wire which was connected to the R1 terminal and ground. Check for continuity between the R1 & R2 terminals on that switch wile it's depressed. Post the results. Here is the wiring sheet. Gene.
__________________
the door switch had become disconnected.....yall rock
Quote:
I'm glad you were able to find the problem and fix it with no cost to you at this time.
__________________
| Display Modes | |
| replaced relay, worked for 2 months, stopped working again. HELP??!! | rebeccapetersen | Refrigerator & Freezer Repair | 3 | 11-11-2009 03:15 AM |
| Replaced motor now unit will do nothing | fastfirebird | Dryer Repair | 0 | 11-01-2009 08:19 AM |
| Fan motor replaced still not working | patrickh | Refrigerator & Freezer Repair | 0 | 08-05-2009 07:54 AM |
| replaced starter freezer stopped again | flip2964 | Refrigerator & Freezer Repair | 3 | 12-09-2007 07:01 AM |
| Replaced Motor and now it doesn't clean | Hot-Point | Dishwasher Repair | 0 | 11-15-2007 04:55 PM |
