Discuss
Dryer does not operate
 in
Dryer Repair
Hello. Any help would be beneficial. My clothes dryer will not power up when the "start" knob/button
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not operate
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-11-2007, 09:53 AM
Dennis Dennis is offline
Junior Member
Dennis is on a distinguished road
Default Dryer does not operate
Model Number: NLV333EB1WW   Brand: Hotpoint   Age: 1 - 5 years
Hello. Any help would be beneficial. My clothes dryer will not power up when the "start" knob/button is actuated/turned on. The unit is plugged in. The circuit breaker controlling it is not tripped. The door closes completely. I suspect the start knob is defective, but it could be anything other than that, too, I assume. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-11-2007, 10:17 AM
Carlos Carlos is offline
Junior Member
Carlos is on a distinguished road
Default
Two things may go Wrong here: the first one it could be the timer, and second, the door switch could be bad:
Check the door swithc first.
  #3 (permalink)
Old 08-11-2007, 03:34 PM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
Quote:
A bad thermal fusr at the back of the vent housing will cause this problem. They are non resetable and need to be replaced if bad. You can jumper around to test or check with ohm meter. A bad door switch will cause same problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Will not operate peaddy Washer Repair 0 07-24-2007 01:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
