My dryer won't heat up and I don't want to call an expensive technician. How do I repair it myself?? Please help.
Remove the toe panel and check if the igniter glows. Post the results.
No the igniter apppears not to be on
Remove the funnel and check the thermal fuse for continuity. - The thermal fuse Part number: 3390719
If the thermal fuse is open, clean the dryer inside and the dryer vent all the way to the outlet. Gene.
