Dryer won't start,I push the start button and nothing happens. Everything was ok and all a sudden it won't start,can anybody tell me what it might be,or what can I check? Any help will be greatly appreciated!!!
Groups: APP Team
Hi. Using the multimeter: First check if there is 240VAC at the outlet. Next - check the door switch. Then - open the rear panel and check thermal cut-off and hi-limit thermostats. The door switch Part number: 3406107
