Rick41
#1 Posted : Tuesday, May 1, 2012 8:06:34 AM(UTC)
Rick41
I am in need of a wiring diagram for an Amana electric clothes dryer model PLE8317W2, serial #9411059089 to diagnose a no heat situation.
#2 Posted : Wednesday, May 2, 2012 3:31:31 AM(UTC)
Sorry but cannot be very helpful
I did find a manual for this series but it was pretty pathetic and did not include any wiring diagrams.
Have you looked in the control console often they store diagrams in there.
Here is a a manual which does not include your unit but may at least give you some insight as to how Amana tends to wire units.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=404
First thing to check with heat problems is the power (only applies to electric unit)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Rick41
#3 Posted : Wednesday, May 2, 2012 4:32:38 AM(UTC)
Rick41
Denman,
Thanks for the info. I inherited this dryer with a house purchase. When I opened the dryer cabinet it became evident that the previous owner or a "service tech." had done some rewiring of the dryer in a less than professional manner. The reference you suggested will be very helpful. Thanks again.
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Need wiring diagram for heating element/thermal fuse/hi-temp fuse forAmana ALE643RAW. (Dryer Repair)
by mdjetdoc 1/13/2016 11:31:57 AM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
need wiring diagram (Oven Repair (including Ranges and Cooktops))
by fudge2009 4/26/2014 3:49:14 AM(UTC)
by tylerlee 8/10/2013 5:19:23 PM(UTC)
need wiring diagram (Dryer Repair)
by rva-fixit 7/28/2013 6:59:31 AM(UTC)
Need wiring diagram for this refer (Refrigerator & Freezer Repair)
by nan1112 7/26/2013 3:47:47 AM(UTC)
Need wiring diagram (Oven Repair (including Ranges and Cooktops))
by Charliez 12/17/2012 3:26:15 PM(UTC)
Need wiring diagram for GE dryer (Dryer Repair)
by rick88ss 10/22/2012 7:55:10 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
wiring disconnected from timer, need wiring diagram (Dryer Repair)
Belarus Chip65 12/2/2011 2:51:45 PM(UTC)
Need wiring diagram for Kenmore 400 series dryer (Dryer Repair)
by MarthaV 7/15/2011 8:03:59 AM(UTC)
need wiring diagram for fridge (Refrigerator & Freezer Repair)
by misterfixall 5/5/2011 4:55:11 AM(UTC)
Need wiring diagram. Help. (Refrigerator & Freezer Repair)
by justin99 2/25/2011 9:13:19 AM(UTC)
Need wiring diagram (Heating, Ventilation, and Air Conditioning (HVAC))
by MagicMan 5/27/2010 6:23:27 AM(UTC)
