Drum doesn't turn. Thought the belt might be broken so I popped the top off and you can't see it from there as the belt seema to be encased in a shroud. Figured I'd have to take the back off but the back and the sides of the dryer are intergral in one piece. There is only a small plate on the bottom of the back and I don't know if that's how you get access to the belt or not. Seems like if you could see the belt from there you wouldn't be able to get it on or off the drum anyway. How do you access the belt to see if its broken?
