| » Admiral Dryer Dead |
Model Number: LNC7749A71 Rev 11 Brand: Admiral Age: More than 10 years
Dryer completely dead. Will not start when timer button is pressed. Interior light does not come on. There is power to the outlet. The door switch clicks when pressed. The timer has been replaced within the last 3 months. What would be the next logical steps to take/parts to check? Thanks in advance for any help...
Related Models |
are you sure you are getting 220 volts coming from recepticle ,are you getting line 1 to neutral,115 volts +line 2 to neutral .115 volts? was light in dryer working prior to failure of dryer?
__________________
yep. I put a meter on the outlet and got 115V from line 1 to neutral and 115V from line 2 to neutral. light in dryer was working prior to failure. is there a fuse (thermal or otherwise) internal to this dryer that I should look for?
Check to see if the belt is broken being over 10 years old there a good chance that it is .Can you take the bottom panel of the dryer,if so you can see if it broken.Another thing is open the dryer door and turn the drum,if it turns easy then the belt is broken.
__________________
| Display Modes | |
| Admiral Dryer won't heat up! | mr1m54u | Dryer Repair | 6 | 08-04-2008 02:33 PM |
| Admiral Dryer no power to light or dryer | Do-right | Dryer Repair | 1 | 01-14-2008 02:15 PM |
| Dead Admiral Dryer | jwboone1981 | Dryer Repair | 1 | 01-01-2008 02:59 AM |
| capacity plus admiral dryer | broken_dryer_forthuachuca | Dryer Repair | 0 | 11-19-2007 06:43 PM |
| how do i replace a belt on an Admiral Dryer | pookie | Dryer Repair | 3 | 10-11-2007 05:07 AM |
